Turn Signal Replacment.
99 civic Si(if that makes a difference): So I accidentally killed the turn signal and that little terminal it plugs into (long story). Where could I find a replacement for the both of them and is there some other name the terminal deally goes by. Thanks in advanced.
A junkyard may be your best bet. Im sure you could get plenty of them at a very small price. And it doesnt matter if it is an si or an ex or etc.
i wouldnt go that far. Im sure ek would work. Just cut your old one out and take it with you, and just make sure they match before you leave. Should be pretty cheap and simple
Well any 99-00 civic blinker bulb and socket will work. just go pick one up at the local junkyard and wire it in. There is no difference in the blinkers on 99-00 si's or ex's or etc.
cool, thanks a bunch for the help bro I really appreciate it. Now if only there were a junk yard that actually had cars that new. Last time I went the newest vic they had was like a 95 lol.
If a junkyard doesnt have it, im pretty sure ebay will. look at yours and look at the newest one you can find. They may match. Im not 100% sure they will but its worth a try. However, im positive that any 99-00 civic bulb and socket will match. Good luck.
Mr_Goodbar
13
Sep 22, 2005 12:07 AM
