Locking hub! need help asap!
Ok guys i've searched and cant seem to find a deffinitive answer. im in the process of doing a b16a swap into my 1990 crx si. ok now my problem is my hub on the passenger side keeps locking up completely when i torque my axel nut down. like it wont even budge a little bit. but if i take the nut off and tap the axel in just a hair the hub will spin freely. i used to have the motor in an identical crx and it worked just fine same axels tranny etc... can anyone help me figure out why it locks up when i tighten down the axel nut?
also on a side note how do i post images on this site? i have pictures of it but it just looks like every other crx hub assembly.
is there a seal in there? to post pics you go to a host like photobucket.com then theres a link on there to post it here or copy the link to the pic and click the little mountains pic its yellow and this will happen when you click it [IMG][/IMG] copy and paste the link inbetween those to img things. if that makes sence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">make sure the dust seal is removed</TD></TR></TABLE>
what and where is the dust seal? is it in the hub?
dude take the hub loose and look at the back side where the axle goes in. there is a dust seal. it is a thin piece of metal. pry that out and put the axle back in...done.
W O T TWO
Nov 26, 2009 09:22 PM
jdmcrxsirmike
Mar 25, 2005 04:20 AM
canuck-mx6
Jun 13, 2003 05:01 PM
