Crank Pulley Bolthredded my timing belt the other day
OK, so I need some help from HT. I just shredded my timing belt the other day. The last block I had, I needed to do the timing and ended up sitting around twiddling my thumbs for a few days, waiting on a new pulley, due to breaking it. I need to ask, I know about the tool thats made, and I read in the haynes, to suspend the flywheel, and break the bolt loose. Now my question is, how do you guys, stop the flywheel. I have tried every angle with different length pry bars, thru the starter hole, with no success. . . And this was using a 24" breaker bar with about a 6ft pipe(no BS). I have gone and purchased a 325ft/lb impact, but now if i couldnt get this loose with the breaker bar, what's the best way to position a prybar in the flywheel to stop it? Anyone's advice would be greatly appreciated, as I am tired of not having a car and would like to get this done tomorrow.
sorry, the motor is d15b2. thanks again
crxcess
Feb 19, 2004 08:24 PM
EK22Tim
Oct 16, 2002 12:59 PM
