Possible to swap for an s2000 engine?
Old Jan 7, 2008 | 02:58 PM
Doyl888's Avatar
Default Possible to swap for an s2000 engine?
Will a f20c engine from a honda s2000 fit in a crx?
Old Jan 7, 2008 | 02:59 PM
CCCP-ef's Avatar
Default Re: Possible to swap for an s2000 engine? (Doyl888)
with enough time and money you can do anything......
Old Jan 7, 2008 | 03:00 PM
LIMITLESS22's Avatar
Are you serious?
Anything will fit... with a little convincing and a lot more $$$
Good luck with that.
Doyl888's Avatar
well the engine, tranny, and ecu are only 4k thats with shipping and its a 240 hp engine soo...
Old Jan 7, 2008 | 03:01 PM
Default Re: (Doyl888)
If this is your 1st swap you're getting in waayy over your head.
Old Jan 7, 2008 | 03:02 PM
Doyl888's Avatar
Default Re: (LIMITLESS22)
the work is not going to be solely by me but also with my sisters b/f who owns a garage so his experience helps a lot
Old Jan 7, 2008 | 03:05 PM
CCCP-ef's Avatar
there is a ton of fab work needed to be done and i dont think that you would be able to use the steering rack...
Theres soo much more involved to make this happen.
No 1. you'd have to convert to RWD
2. You'd have to cut half the car apart to fit the engine and trans.
Just start with something more simple(like a k-series swap).
Old Jan 7, 2008 | 03:06 PM
Doyl888's Avatar
so thats the best power/easiest swap for me to do?
Old Jan 7, 2008 | 03:07 PM
CCCP-ef's Avatar
k20 or k24
Old Jan 7, 2008 | 03:08 PM
Doyl888's Avatar
Default Re: (CCCP-ef)
k thank you guys i will look into it.... and i said easiest with the most power, cause i know b16 is easier but i want more then that when i swap so i dont swap like every year
Old Jan 7, 2008 | 03:09 PM
No. K swap is definatly not the easiest to do.
Your best bet is to use the search feature and research different swaps.
Old Jan 7, 2008 | 03:36 PM
gibsanez's Avatar
I saw get your hands on a Type R swap or maybe even an H22, but the R would be a more direct swap with plenty of pep.
Old Jan 7, 2008 | 03:37 PM
2215_EF's Avatar
K series swap would be good if you have 7 to 10 grand on hand.
if you dont you can aim cheaper and still make good power.
maybe type R, or H22 with a b series trans.
depends on personal preference
Old Jan 7, 2008 | 04:03 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">Question:
What's the BEST engine for my Honda?
Answer:
125cc Honda dirt bike motor. It weighs under 50lbs, revs to 10000rpms, and makes 320hp/liter.
There, now that we solved the question that is constantly on everyone's mind, let's talk about pizza.
Seriously now, the best engine for your honda is WHATEVER YOU CAN AFFORD TO BUY!
If you have $1000, DOHC ZC.
If you have $2000, get a 1st gen b16a. It'll cost that much to get it in.
If you have $4000, get a GSR/B18C1.
If you have $5500, get a ITR/B18C5.
If you have $10K, and no use for your car for a month or two... get a K20.
Edited for the Whiners:
This is NOT a complete list, as there are mini-mes, LS-VTEC swaps, budget/poor man's ITRs, etc. Use the damn search button a bit more religiously.
What's the best engine for boost... the one that gets TUNED properly.
What's the best engine for drag racing... the one you spend the most money on making FAST.
What's the best engine for road racing... same thing.
What's the most reliable engine... the one you MAINTAIN religiously.
What's the cheapest engine... the one that's in your car.
Old Jan 7, 2008 | 05:11 PM
STREETWERKZ's Avatar
Default Re: Possible to swap for an s2000 engine? (dr_latino999)
i thought i read of a rumor of F2K swap.
s2k motor with K series trans.
Old Jan 7, 2008 | 05:16 PM
mullet eater's Avatar
Default Re: Possible to swap for an s2000 engine? (STREETWERKZ)
I heard that rumor also. Not shure if its worth the time and money! But I bet its fast!
Old Jan 7, 2008 | 05:19 PM
Default Re: Possible to swap for an s2000 engine? (mullet eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mullet eater &raquo;</TD></TR><TR><TD CLASS="quote">I heard that rumor also. Not shure if its worth the time and money! But I bet its fast!</TD></TR></TABLE>
if i knew about that before i started on my k swap, i would have purchased the f22c motor instead. it's worth it.
do i think the OP has the money/time/knowledge to do this swap? that's a different story.
Old Jan 7, 2008 | 06:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mullet eater &raquo;</TD></TR><TR><TD CLASS="quote">I heard that rumor also. Not shure if its worth the time and money! But I bet its fast!</TD></TR></TABLE> Right Here
Old Jan 7, 2008 | 06:57 PM
Mr.Meowsome's Avatar
isnt there an f2d?
Old Jan 7, 2008 | 06:59 PM
juanchoenuncrx's Avatar
* B A N N E D *
yeah if you wanna go that far is better and easier to go with a k20 or k24 . if you do the s2000 motor you gonna have to build a whole new car like cutting the car in half and is a lot of time, money and i never seen anything like that. i seen that swap but on ae86 corollas but not crxs. just stay with a fwd.
Old Jan 7, 2008 | 07:18 PM
Default Re: Possible to swap for an s2000 engine? (Mr.Meowsome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Meowsome &raquo;</TD></TR><TR><TD CLASS="quote">isnt there an f2d?</TD></TR></TABLE>
yes, but thats a different F series. you're talking about the H/F motor. and yes, quite a few people have done an F2D swap.
Old Jan 7, 2008 | 07:20 PM
Hamstr323's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">i thought i read of a rumor of F2K swap.
s2k motor with K series trans. </TD></TR></TABLE>
also HEARD that a certain guys with a black coupe was supposed come back to pro all motor with this setup
Old Jan 7, 2008 | 07:50 PM
Default Re: Possible to swap for an s2000 engine? (Hamstr323)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hamstr323 &raquo;</TD></TR><TR><TD CLASS="quote">
also HEARD that a certain guys with a black coupe was supposed come back to pro all motor with this setup</TD></TR></TABLE>
really? it's been a long time.
Old Jan 7, 2008 | 07:53 PM
Hamstr323's Avatar
really? it's been a long time. </TD></TR></TABLE>
yea it has sad that it's just been sitting but who knows he told a good friend of mine that those were the plans but... you know how things go
but I would love to see that car back in action
BTW gj bro looks like it's all coming together for you
