Integra won't move in gear???
Old Jan 7, 2008 | 02:28 PM
Red_Si's Avatar
Default Integra won't move in gear???
I just put in a s4c tranny in my integra with a b20. I was having a starting problem when i got it all done and i finally got that figured out. I can now push the clutch in and start the car with no problems.
I know that i need to bleed my clutch, it has air in the line for sure and the fluid is very very dirty.
I can push the clutch in and shift all gears without any grinding.
While the clutch is pushed in and the shifter in 1st gear, i can let the clutch out and the car doesn't go anywhere.
My question is, could this be a problem that bleeding the clutch could solve? if not, what could cause this?
I'm lost and i really need help. I don't think anything went wrong with the trans install, everything went pretty smooth. What could be my problem, any little thing you can think of can help so that i can start diagnosing the problem tomorrow. So far the only thing i can think of is that i need to bleed the clutch. Help! TIA
Old Jan 7, 2008 | 02:54 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Integra won't move in gear??? (Red_Si)
this may be highly unlikely, but check your DS axle
Old Jan 7, 2008 | 04:02 PM
JDM92da6's Avatar
i did a clutch not too long ago and took it for a ride and passenger side axel poped out,check that 1
Old Jan 7, 2008 | 04:28 PM
Red_Si's Avatar
so basically check my axle's? I'm pretty sure they are both in there but i will check tomorrow.
Is my theory at all possible?
Old Jan 7, 2008 | 05:34 PM
Red_Si's Avatar
ok i got a little bit of an update!
i went out to the car to see if the speedometer was registering anything, so i put it in second gear and let the clutch out and the speedo jumped to like 30 mph!!! This can only mean that one of my axles aren't in completeley right????
Old Jan 7, 2008 | 05:55 PM
all-mtr-teg's Avatar
Default Re: (JDM92da6)
Had the same experience here.
Old Jan 7, 2008 | 07:26 PM
NH538DB8's Avatar
One of your axles is not installed correctly. The sensor in the trans sees that the output shaft is spinning but because there is no load on one side of the trans and you don't have a diff all the power is going to that side. Its the same reason that cars without an LSD do one wheel burnouts. Once one tire is spinning then all the power goes to that wheel.
Old Jan 8, 2008 | 06:15 PM
JDM92da6's Avatar
yea dude,your axels arent right,pull them out and make sure the c clips ate the ends are in tact
Old Jan 9, 2008 | 03:47 PM
Red_Si's Avatar
yea i got it fixed, the passenger side axle wasn't in all the way. She runs and drives fine now!!! Thanks guys!
92sully
Sep 17, 2010 08:19 AM
kojack_0
Feb 10, 2010 12:39 PM
Red_Si
Jan 9, 2008 03:47 PM
H.
Oct 10, 2004 07:05 PM
92-EG6
Aug 25, 2003 10:02 PM
