Ticking noise on #1 piston only when cold started.
Old Jan 7, 2008 | 01:31 PM
GSX 4G63T's Avatar
Default Ticking noise on #1 piston only when cold started.
My buddy's civic d15a7 is starting to tick on number 1 piston area. After the intial cold start it sounds like a V8 at idle. After it warms up its ticking noise is to a minimal. Then the whole thing happens again after cold starts. He checked valve lash within, it's spec. Anyone???
Old Jan 7, 2008 | 01:42 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
The magical word "piston slap" comes to mind, lots of miles on the d?
Old Jan 7, 2008 | 01:49 PM
GSX 4G63T's Avatar
Default Re: (ComeOnKip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip &raquo;</TD></TR><TR><TD CLASS="quote">The magical word "piston slap" comes to mind, lots of miles on the d?</TD></TR></TABLE>
only 113987 miles used for daily driver
Old Jan 7, 2008 | 03:27 PM
GSX 4G63T's Avatar
only changed t belt w/ water pump. do i need to change pistons then???
Old Jan 7, 2008 | 06:13 PM
1kleenef's Avatar
Default Re: (4163175587)
somewhat same problem in for an answer
Old Jan 7, 2008 | 06:42 PM
StorminMatt's Avatar
Default Re: Ticking noise on #1 piston only when cold started. (4163175587)
D15A7? What is that on? I've heard of a D15B7. But that came on 1992-1995 Civics. Regardless, unless you plan to swap to B-series or beyond, you can probably pick up a used longblock in better shape than what you have for a song (or nothing). This would certainly be MUCH more cost effective than tearing things down.
b20vtech
Dec 25, 2005 07:08 AM
fxrob
Feb 20, 2005 10:31 AM
AmginE
Apr 15, 2004 12:56 PM
GruvyTune
Aug 27, 2002 09:47 PM
Cor ey
14
May 1, 2002 06:18 AM
