B16, Idles at 4200 rpm's and stays there on start up
Old Jan 7, 2008 | 01:15 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default B16, Idles at 4200 rpm's and stays there on start up
Just started the engine for the first time yesterday, and it revs to 4200 and stays there. I dont have vtec or knock sensors hooked up, and my vacume lines are good. I dont get my throttle cable untill Friday so its not hooked up. I searched and couldn't find anything?
Old Jan 7, 2008 | 01:17 PM
GSX 4G63T's Avatar
Timing is not set right. I am sure! one tooth or two I bet is off. Buy a timing light and watch it. It is not within 1-3 degree in spec.
Old Jan 7, 2008 | 01:31 PM
PuroMotor's Avatar
I was having the same problem with a d16 and it turned out to be timing..... check it .. good luck
Old Jan 7, 2008 | 07:03 PM
traxxasx's Avatar
take your fitv valve out and take it apart and screw the white thing inside toghether. Mine came apart inside which caused my car to idle at 3k.
Old Jan 8, 2008 | 05:14 AM
Dc4iNtEgRa's Avatar
Default Re: (traxxasx)
Thats what I was affraid of.... Guess it will be a busy weekend again.
Old Jan 8, 2008 | 07:00 AM
b16a1eg6's Avatar
Default Re: (Dc4iNtEgRa)
If your coolants low it will do that.
Old Jan 8, 2008 | 04:16 PM
Dc4iNtEgRa's Avatar
Default Re: B16, Idles at 4200 rpm's and stays there on start up (Dc4iNtEgRa)
I talked to a Honda mechanic, and he said even if the timing belt is off a tooth or two, it shouldn't make it idle that high.
Old Jan 8, 2008 | 04:25 PM
Crx Jimmy's Avatar
spray carb cleaner around all the intake gaskets, really soak them. if the idle changes you have a leak. also make sure you have the brake booster line hooked up with the one way valve on the right way
Old Jan 8, 2008 | 05:00 PM
Dc4iNtEgRa's Avatar
Default Re: B16, Idles at 4200 rpm's and stays there on start up (Crx Jimmy)
Thanks... I will check that...
Old Jan 8, 2008 | 06:03 PM
ludesrv's Avatar
Was the tps sensor replaced during the swap (common to be broken on imported engines)? You should check the voltage of the middle wire on the tps sensor plug. At warm idle it should read 0.5 volts. A friend's H22 accord had it replaced and it was idling at 3000rpm. The TPS was reading over 2volts on the meter. It's worth a check since it takes a few minutes to do.
Old Jan 10, 2008 | 05:45 PM
Dc4iNtEgRa's Avatar
Default Re: (ludesrv)
TPS is good... any other ideas??? Im lost. Thanks, Alex
BmoreEG
May 19, 2013 09:11 AM
JasonST
Apr 8, 2012 11:52 PM
Tatakai
Apr 25, 2007 10:41 PM
NoVALude
Nov 20, 2006 11:02 AM
dpine
Apr 11, 2004 02:18 PM
