Head Light Alignment ?
Old Jan 7, 2008 | 11:47 AM
xelloss's Avatar
Default Head Light Alignment ?
Hi there...does anyone have a head light alignment problem? I know that I can adjust the up and down of the lighting angle, but how about left and right? How do I know if my light beam is pointing to the right area?
I"m driving a 97 civic by the way..with the OEM head light housing...
Please give me a little hit...I think my light beam angle is kinda wrong...
Old Jan 7, 2008 | 11:49 AM
OMGWTFBBQ!'s Avatar
There are two adjustment gears, you'll need a philips head screw driver. The vertical adjustment is towards the grill, the horizontal is toward the fenders, and is a bit harder to find and adjust, but its possible.
Old Jan 7, 2008 | 12:00 PM
xelloss's Avatar
Default Re: (OMGWTFBBQ!)
I know there is a vertical adjustment gear...but I just found that there is a horizontal too...thanks for that...but, I can't tell if my adjustment is correct...i mean the if beam is pointing to the same area...and the amount of beam is even
Old Jan 7, 2008 | 12:05 PM
ifIexplode's Avatar
https://honda-tech.com/zerothread?id=2086368
Old Jan 7, 2008 | 12:28 PM
xelloss's Avatar
Default Re: (ifIexplode)
OH...good stuff....
thanks a lot ifIexplode...
Old Jan 7, 2008 | 01:05 PM
ifIexplode's Avatar
Youre Welcome, Good Luck
Old Jan 7, 2008 | 02:57 PM
xelloss's Avatar
sorry, one more question guys....it says the 0 mark on the Horizontal gear should be pointed in the middle of the L and R, but after how many turns? The 0 mark will hit the mid point of the L R every turn...is there any guide line?...kinda dump question..but just want to know...Anybody?
Thanks a Ton....
Old Jan 7, 2008 | 10:41 PM
xelloss's Avatar
Default Re: (xelloss)
Well, I tried to adj the Left and Right of the head light...nothing happened when I turned the Horizontal gear... the light beam didn't move a bit....only the vertical gear works...is that normal? Do all the head lights of USDM vehicles tended to pointing a bit to the left?
Old Jan 8, 2008 | 01:13 AM
OMGWTFBBQ!'s Avatar
They should be pointing straight ahead, but your right side headlight should be a tiny bit lower than your left light.
jaltman
Honda Civic (2001 - 2005)
May 22, 2014 11:14 AM
DrastikJDM4door
Jul 28, 2007 07:30 AM
brucesi
Nov 19, 2006 10:22 AM
civicrights
Oct 19, 2003 01:47 PM
