anyone using ebay flex grinders?
Old Jan 7, 2008 | 11:08 AM
RACEPAK's Avatar
Default anyone using ebay flex grinders?
hello,
i saw a rotary tool/flex grinder like that at a bike shop near my house,
and i thought about buying one for myself,
is it better/stronger then a dremel?
thanks
Old Jan 7, 2008 | 11:23 AM
PPLH8R's Avatar
Default Re: anyone using ebay flex grinders? (RACEPAK)
I have a tool very similar but it is made by Dumore. It wasnt cheap but it works very good. The one I have is WAY stronger than any Dremel. Its a very nice tool to have if you can afford it.
Old Jan 7, 2008 | 11:59 AM
Flashmn's Avatar
Default Re: anyone using ebay flex grinders? (PPLH8R)
the motor will attract metal dust like no tomorrow though.
Those are a good alternative to air grinders.
Old Jan 7, 2008 | 12:15 PM
hootiehoo's Avatar
Default Re: anyone using ebay flex grinders? (Flashmn)
it can be a bitch. you you bend the line...the cable will snap. you have to keep the line as straight as possible, like hang the motor from the cieling and have the tool come straight down.
Old Jan 7, 2008 | 03:03 PM
marcin's Avatar
Default Re: anyone using ebay flex grinders? (hootiehoo)
that looks like it only takes 1/8 in shank stuff. you will want something that will work with 1/4" shank if you want to port.
m.
Old Jan 8, 2008 | 07:34 AM
Top Ramen's Avatar
Default Re: anyone using ebay flex grinders? (marcin)
I got one from Eastwood that I use for porting work. It does not have the torque of a good electric die grinder (which I use for roughing things out) but is easier to control and works fine for most porting work with the right bits and rolls. It is also nice for detail polishing work.
Best of luck with your project.
Sprockets
Nov 23, 2011 08:31 AM
spooncivic1
Jul 4, 2006 02:45 PM
94cordlx
Jan 10, 2006 05:07 AM
Devo94ac
Sep 22, 2005 09:39 PM
allablur
Jan 12, 2004 11:32 PM
