My new build.
Old Jan 7, 2008 | 10:49 AM
u n v kenny's Avatar
Default My new build.
Last Wednesday I blew my motor on the interstate. I may have spiked it or just overrevved. However I pulled the valve cover off and saw coolant in my head so I know I have a blown headgasket. Did a leakdown test: cyl 1 and 3 are good, 2 is not so good and 4 is gone. Tonight I'm going to pull off my head and hope that it's just a blown head gasket and not a bent rod or bent valves or whatever. If so, here will be my new daily driver build.
Sleeve my block
700cc+ injectors
Hondata
Eagle Rods
JE Pistons
Cometic Head Gasket
ACL Bearings
ARP head studs
Fix my tie rod boots, oil pan gasket and rear main seal. Put in my stage 3 clutch and an air/fuel gauge.
Should be done by the end of February or March-ish.
I will keep you updated as the build continues.
Old Jan 7, 2008 | 12:42 PM
TDogg Teg's Avatar
Default Re: My new build. (u n v kenny)
Post pics of the existing head and pistons when you get it off, mang.
Old Jan 7, 2008 | 12:50 PM
Default Re: My new build. (TDogg Teg)
I have my camera on my phone, but they should still come out ok. I'll do that this evening.
Old Jan 7, 2008 | 09:11 PM
Here I am draining the oil, check out the grey murky color. (radiator fluid and oil mixed)
About to take the cams and gears out of my head.
Notice the radiator fluid?
Cams and gears out.
Don't ask, but this is how Acura techs take off the intake manifold.
and this is the conclusion to my blown motor.
Old Jan 7, 2008 | 11:15 PM
blue2000em1's Avatar
damn dude cracked sleeve ftl.Built sleeve b series ftw,what are you hp goals???? as far as for the new build????
Old Jan 7, 2008 | 11:40 PM
TDogg Teg's Avatar
Default Re: My new build. (blue2000em1)
Judging by the injector size, I'd say 400+ whp on pump? That'd be kool!
Old Jan 8, 2008 | 12:18 AM
808DB1's Avatar
haha those shirts look familiar , i my self am a acura tech also in maui , hawaii that is
Old Jan 8, 2008 | 04:32 AM
Default Re: (808DB1)
HP will be around 300hp+ around 7-lbs.
It will be built for about 700hp+ but I will be keeping the boost down low. I'm building my block bulletproof and I don't want this **** happening again. Plus if I turn around an sell it someday people will like a built motor.
Old Jan 8, 2008 | 06:07 AM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: (u n v kenny)
LOL!
Old Jan 8, 2008 | 06:46 AM
Adam.C's Avatar
looks like you were running an fmu. that was probably the problem. get a good tune next time and that prob wont happen
Old Jan 8, 2008 | 06:50 AM
Default Re: My new build. (Adam@VisionaryAuto)
Hondata is a must this time.
Old Jan 8, 2008 | 10:04 AM
SpoolnG2's Avatar
Did you have anything pulling timing out? How much boost were you running?
Old Jan 8, 2008 | 02:55 PM
Tippyman's Avatar
Default Re: My new build. (SpoolnG2)
Old Jan 8, 2008 | 03:16 PM
laziebun's Avatar
holly crap that looks like just like mine
and my new AEBS block from Inline Pro
Good luck on your build
Old Jan 8, 2008 | 04:40 PM
urbansi's Avatar
Default Re: My new build. (laziebun)
well as long as we are swinging our dicks with broken sleeved blocks heres mines
Old Jan 8, 2008 | 05:25 PM
Schister66's Avatar
Man U FTW
Default Re: My new build. (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">well as long as we are swinging our dicks with broken sleeved blocks heres mines</TD></TR></TABLE>
lol...i love carnage though
Old Jan 8, 2008 | 05:46 PM
jdmcoop's Avatar
Default Re: My new build. (Schister66)
Sorry about the motor but the good thing is doing the rebuild so it can handle some big power.
We can install some Darton MID sleeves that can handle about anything you can throw at it. ERL is a distributor for Darton so we have the sleeves in stock or we already have some B18C motors sleeved with Darton MID's and the only thing they are waiting on the to be cylinder honed. PM me for more details.
Old Jan 8, 2008 | 06:01 PM
urbansi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
lol...i love carnage though </TD></TR></TABLE>
yeah me and a couple friends have a laugh about it now... but when the motor first went they took me out and got me hammered cuz i was so depressed.
Got a nice sleeved block now so its all good.
Old Jan 9, 2008 | 07:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcoop &raquo;</TD></TR><TR><TD CLASS="quote">Sorry about the motor but the good thing is doing the rebuild so it can handle some big power.
We can install some Darton MID sleeves that can handle about anything you can throw at it. ERL is a distributor for Darton so we have the sleeves in stock or we already have some B18C motors sleeved with Darton MID's and the only thing they are waiting on the to be cylinder honed. PM me for more details. </TD></TR></TABLE>
How much?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">Did you have anything pulling timing out? How much boost were you running?</TD></TR></TABLE>
7lbs I may have spiked it and not noticed.
Old Jan 9, 2008 | 07:32 AM
SpoolnG2's Avatar
Did you have something pulling timing out? I'm assuming due to your FMU that you werent running a EMS and also had nothing pulling timing. So that nice crack in your sleeve is most likely due to detonation. Is all this correct to assume? Good luck with the new build. Some may advise to use a different rod if your gonna build such a solid setup.
Modified by SpoolnG2 at 5:13 PM 1/9/2008
Old Jan 9, 2008 | 07:58 AM
jdmcoop's Avatar
Pm'd you with a price.
Tong.Y
Jun 5, 2011 09:17 PM
kwell
Sep 16, 2010 11:28 PM
lilshady6796
May 23, 2009 11:21 AM
scspeed
Apr 18, 2009 01:54 PM
u n v kenny
Jan 10, 2008 07:45 AM
