New idea for turbo oil feed? Could this work...
I don't know if anyone has ever tried this, but if not can you guys think of any reason it wouldn't work...this is only for dohc VTEC.
Instead of using some T-fitting adapter in the oil pressure sender hole or adding a costly sandwich adapter to get oil output, is there any reason the plugged hole in the head usually used for LS/VTEC adapter fitting can't be used to feed the turbo? Just put a 3/8NPT-4AN fitting in there, you could have a shorter, cheaper, easier, more reliable feed line...at least that's my theory. I thought this could work with DOHC VTEC blocks by drawing off the internal oil passage feeding the head.
Cool, thanks...I think I may use a 3/8 to 1/8 reducer bushing and run a 1/8 hardline all the way to the turbo and skip the AN fittings w/braided lines.
I will be running a t3/t4 non-ball bearing turbo on a stock B16, do you use a restrictor, or would you know if I should use one and if so what size...thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE »</TD></TR><TR><TD CLASS="quote">You don't need a restricter</TD></TR></TABLE>
Thanks, I'm happy to know that, it will make the setup even cheaper and easier than I thought.
I can get a brass reducer for a couple bucks at Home Depot, and an unbent 1/8 hardline (I think they are supposed to be for brakes) at Murray's or Auto Zone for like $5 or so, they come in several lengths and I'll just bend it to shape. Since I have a total budget of under $1000 for my turbo setup, going from like $50 down to $10 for the oil supply helps!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">pics of said setup?</TD></TR></TABLE>
I don't have pics since I just thought of it, but since PHDZINE has already done it perhaps he will grace us with some photos? I will take some when I'm done though.
I can get a brass reducer for a couple bucks at Home Depot, and an unbent 1/8 hardline (I think they are supposed to be for brakes) at Murray's or Auto Zone for like $5 or so, they come in several lengths and I'll just bend it to shape. Since I have a total budget of under $1000 for my turbo setup, going from like $50 down to $10 for the oil supply helps!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">pics of said setup?</TD></TR></TABLE>
this is what you want http://store.summitracing.com/...w=sku
that connects to the vtec head at the 3/8th opening on the dizzy side. you can use it for ls/vtec conversion kits or you can tee it to feed the turbo and run your ls/vtec conversion its simple and reliable.
Yeah I saw those, I have been researching what might be the best way, also what would be most cost-effective. After shipping costs that fitting will run me about as much as the whole setup I concocted. Since the head is NPT, and the turbo is NPT, I wondered why should I convert to AN lines/fittings then back again. The aluminum fittings and stainless lines can get pricey, even though they look good. And I don't really need anything versatile or with T-fittings, It's already a stock VTEC block so I just want something simple to run turbo.
But I did think of the same idea you had for using it for LS-V and turbo simultaneously. Actually there is an adapter fitting I found on Ebay that has multi-port output so you don't have to stack an extra fitting on there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger »</TD></TR><TR><TD CLASS="quote">Yeah I saw those, I have been researching what might be the best way, also what would be most cost-effective. After shipping costs that fitting will run me about as much as the whole setup I concocted. Since the head is NPT, and the turbo is NPT, I wondered why should I convert to AN lines/fittings then back again. The aluminum fittings and stainless lines can get pricey, even though they look good. And I don't really need anything versatile or with T-fittings, It's already a stock VTEC block so I just want something simple to run turbo.
But I did think of the same idea you had for using it for LS-V and turbo simultaneously. Actually there is an adapter fitting I found on Ebay that has multi-port output so you don't have to stack an extra fitting on there.</TD></TR></TABLE>
you can buy 3/8th to 1/8th npt adapters just search on google they should be around $5~$8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaveF »</TD></TR><TR><TD CLASS="quote"> there is a smaller 1/8 port toward the bottom of the head that could be used as well
copper color plug @ the bottom, under the dist mount location. </TD></TR></TABLE>
Aha, I didn't notice that little thing under there, that would be even better to not use a 3/8-1/8 reducer bushing, make the line a few inches shorter and make it less noticable. Thanks for the tip.
Griffin@Camtech
Feb 24, 2004 05:58 PM
