Help I need a question answered 57trim or t3 60-1 for 400++whp
Old Jan 6, 2008 | 10:46 PM
blue2000em1's Avatar
Default Help I need a question answered 57trim or t3 60-1 for 400++whp
Okay guys I'am having alot of trouble on deciding a turbo to achieve my 400whp on a future build.The setup will consist of a ls/vtec simple piston rod setup(81.5mm). A b16 head with a built valve train,gsr cams,max bore tb,and a Itr im. I've been looking into the Garrett t3/t4 57trim (.63a/r) stage 3 wheel, and the t3 60-1 stage(.63a/r).I know alot of people has achieved 400whp horsepower with there Garrett 57 trim turbos. But I have notice also It was between 17-20psi with the setup I'll be doing to achieve that kind of power.I know that people say never to look at PSI as a primary means to measure power.But I do also hear that that turbo runs out of usuable energy from 18-22 psi.Now if I where to go that route(t3/t4 57trim stage 3 .63ar) and have the boost at 20psi to reach my goal of 400whp. Can that cause alot of stress to the turbo at that kind of psi???? Opinions and experience please????Also has anyone had any experience with the t3/60-1 stage 3 .63ar?????? Hear this turbo can support up to 450-550+whp. I just want a nice setup of 400++ horsepower on 93 octane somewhat spool fast but has room to grow.And maybe 500whp on racegas(E85/C16).So what do you guys think I should go with for my goal??????
Old Jan 6, 2008 | 11:07 PM
b20vtech's Avatar
Default Re: Help I need a question answered 57trim or t3 60-1 for 400++whp (blue2000em1)
LOL, dude u and me are in the same boat brother!!
Old Jan 6, 2008 | 11:16 PM
Default Re: Help I need a question answered 57trim or t3 60-1 for 400++whp (b20vtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">LOL, dude u and me are in the same boat brother!! </TD></TR></TABLE>
lol?????anyone
Old Jan 7, 2008 | 12:47 AM
Turbogixxer's Avatar
sc61
Old Jan 7, 2008 | 02:02 AM
blackeg's Avatar
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">sc61</TD></TR></TABLE>
good call.
i make 415 with a 60-1 at 17 psi also on an lsvtec but im at 84mm bore.
i wouldnt get the 57 trim. it will be maxxed on your initial goals and you will have to upgrade if you want any more power
Old Jan 7, 2008 | 07:22 PM
Default Re: (blackeg)
any other people, so 400whp is the max people has done with there 57trims with 93 octane??????
Old Jan 7, 2008 | 07:39 PM
Schister66's Avatar
Man U FTW
-57 trim .82 ar
-60-1 stage V turbine
-Silver Surfer
-Garrett GT3076r
-Borg Warner S258
In MY list of preference...the bottom one being the best pick IMO
Old Jan 7, 2008 | 08:34 PM
quicksilver1689's Avatar
i ♥ snails
yeah i really like seeing those BG s258 setups they do very well
Old Jan 7, 2008 | 09:42 PM
Schister66's Avatar
Man U FTW
I've said it in the past, but the Borg Warner S256 WILL BE my next turbo. They're awesome and don't recieve nearly enough credit. People instead opt for the GT3076r because its "ball bearing" which to most people means it will spool faster. If only people were more educated about their choices before picking them for the wrong reasons
Old Jan 7, 2008 | 09:47 PM
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">I've said it in the past, but the Borg Warner S256 WILL BE my next turbo. They're awesome and don't recieve nearly enough credit. People instead opt for the GT3076r because its "ball bearing" which to most people means it will spool faster. If only people were more educated about their choices before picking them for the wrong reasons </TD></TR></TABLE>
I hope that's not about me dude, I ask you and other people for advise that's been there and done that.And about this Bw s256 how much do they retail for ,and what is the specs on this turbo????
Old Jan 7, 2008 | 09:49 PM
Schister66's Avatar
Man U FTW
Default Re: (blue2000em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2000em1 &raquo;</TD></TR><TR><TD CLASS="quote">
I hope that's not about me dude...</TD></TR></TABLE>
No, that was in reference to the large amount of ignorant people who, rather than researching and learning, merely follow the bandwagon and suggestions from other equally ignorant people. This subject generally gets me all pissed off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2000em1 &raquo;</TD></TR><TR><TD CLASS="quote">about this Bw s256 how much do they retail for ,and what is the specs on this turbo????</TD></TR></TABLE>
PM Turbodano and see. I know he has some of the better pricing around on Borg Warner stuff. Tell him Schister66 sent you
Old Jan 8, 2008 | 04:59 AM
mikex1021's Avatar
im running a 57trim t3/t4 tubonetics turbo 63 a/r 81.5 bore on a gsr motor, made 401 at 16psi.
Old Jan 8, 2008 | 05:20 AM
TheShodan's Avatar
Moderator
Default Re: (mikex1021)
The S256 and STC Silver Surfer can do a fantastic job of making 400whp at under 17-18psi, because of their compact size, yet high flowing capabilities. The Silver surfer is about $850 compared to the S256 which is about $1150. The Silver surfer uses a 60-1 compressor wheel in an extrude honed t04b compressor housing (the way it originally came before the "S" cover options) and uses a P-Trim turbine wheel instead of the Stage III which is on most peoples list, and though runs well, really puts stress on the exhaust wheel. The S256 uses an extended tip compressor wheel, which is an extention of the distance between the inducer and exducer. The real advantage is not only a great turbo that reaches positive manifold pressure quickly, but it runs with much lower IAT temperatures that allow the unit to run more boost, safely. The S256 also comes standard with a P-Trim exhaust wheel, and does well. B16a4 ran over 220whp on only 6psi of boost from the silver surfer, and more tests have been performed with the S256 (though at least 350whp or more should be the goal for one that is going to purchase it).
Let me know if you need more information on either unit
Old Jan 8, 2008 | 07:19 AM
Schister66's Avatar
Man U FTW
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Let me know if you need more information on either unit</TD></TR></TABLE>
Mac, your title is true to life, but i think it'd look better in pink
Old Jan 8, 2008 | 11:33 AM
TheShodan's Avatar
Moderator
Mac, your title is true to life, but i think it'd look better in pink </TD></TR></TABLE>
Hahaha. I'm not Yashio Factory, but we'll see.
Old Jan 9, 2008 | 12:21 PM
I'am loving this s256 more and more.But hey Shodan does the s256 spool faster than it's competive garrett gt30r??????
Old Jan 9, 2008 | 12:50 PM
22's and Man Boobs's Avatar
T3/60-1
Old Jan 9, 2008 | 12:53 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22’s and Man ***** &raquo;</TD></TR><TR><TD CLASS="quote">T3/60-1</TD></TR></TABLE>
Care to elaborate? I really dislike when people suggest something (other than when its blatantly obvious) without any rationale to back their post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2000em1 &raquo;</TD></TR><TR><TD CLASS="quote">I'am loving this s256 more and more.But hey Shodan does the s256 spool faster than it's competive garrett gt30r??????</TD></TR></TABLE>
They're close enough where you probably wouldnt notice a difference.
Old Jan 9, 2008 | 12:59 PM
morgan@synapse motorsport's Avatar
They're close enough where you probably wouldnt notice a difference. </TD></TR></TABLE>
what are you basing this on. i still havent even seen a dyno chart of an s256 on a honda or a close comparison, and i have looked.
my car is coming apart tomorrow for our s256 test.
Old Jan 9, 2008 | 01:08 PM
Schister66's Avatar
Man U FTW
Default Re: (mike@synapse motorsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">what are you basing this on. i </TD></TR></TABLE>
The numbers of dyno sheets i've seen with RPM vs MAP logs. There are several GT30r dynos floating around and with a little time, you can snag a few S256 dynos along the way.
I can't wait for the results and some "unbiased" data
Old Jan 9, 2008 | 01:15 PM
I can't wait for the results and some "unbiased" data</TD></TR></TABLE>
well if they are out there i havent seen any. someone shoot me a pm with a link please.
yes our results will be unbiased, completely proffesional, and on video tape. i noticed you put the word in quotes, i hope you arent trying to insinuate that we would attemp to scew the results.
to the OP i think a 57 trim will get the job done for 400whp. weve done it several times with this turbo, and not in the 20psi area, closer to 16psi more so.
Old Jan 9, 2008 | 02:18 PM
to the OP i think a 57 trim will get the job done for 400whp. weve done it several times with this turbo, and not in the 20psi area, closer to 16psi more so.</TD></TR></TABLE>
Thanks I'am happy to hear that the 57trim can reach that goal without running out of efficency,Now as far as the gt30r vs S256 I can't wait to see the results .
Old Jan 9, 2008 | 02:41 PM
Sr420Det's Avatar
Im pretty much after the same thing and had it narrowed it down to the sc61. Let me know if you get that brog price but I think its a little to expensive for my taste.
Old Jan 9, 2008 | 08:21 PM
uhhhhh....... perhaps my car that is in my sig??????? any specific questions though feel free to ask
almostboostedgsr
Apr 9, 2007 08:18 PM
IntegraGSR(-1)
Aug 10, 2005 05:30 PM
b18c1wes
Apr 21, 2005 05:30 PM
Turbo-Honda
Apr 12, 2004 03:53 AM
oemDC2
Nov 25, 2003 03:44 AM
