H22 oil leak
Old Jan 6, 2008 | 06:04 PM
Colby71's Avatar
Default H22 oil leak
Hello I have an h22 in an eg hatch with a m2b4 trans. I have a new oil leak it is getting all over my drivers/timing belt side of my suspension. I have not gotten a good look yet becues I had to go to work. It could of been falling on my axle witch spun it all over the suspension/stearing rack. I was just wondering if there is a common place for leaking back there. It is comming from below my Intake manifold. It could be from the trasn also.
Old Jan 6, 2008 | 08:33 PM
vlang29's Avatar
Default Re: H22 oil leak (Colby71)
oil cooler o-ring is very common
Old Jan 7, 2008 | 12:20 AM
Acidcrakker's Avatar
Default Re: H22 oil leak (vlang29)
Yeah but Oil Cooler O-Ring leak getting oil on the T-belt side of the motor. That dont sound right
Old Jan 7, 2008 | 05:59 AM
vlang29's Avatar
Default Re: H22 oil leak (Acidcrakker)
ya, i am a bit unsure of the description
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Colby71 &raquo;</TD></TR><TR><TD CLASS="quote"> It is comming from below my Intake manifold. It could of been falling on my axle witch spun it all over the suspension/stearing rack.</TD></TR></TABLE>
sounds like oil cooler.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Colby71 &raquo;</TD></TR><TR><TD CLASS="quote"> I have a new oil leak it is getting all over my drivers/timing belt side of my suspension. </TD></TR></TABLE>
sounds like oil pump/front main seal
Old Jan 7, 2008 | 11:05 AM
Colby71's Avatar
I am on my way out to check it out in a fue min. ill will post what it is.
Old Jan 7, 2008 | 11:11 AM
Default Re: (Colby71)
Pics help alot too!
Old Jan 7, 2008 | 11:26 AM
es_squared's Avatar
I just had a similar problem that I thought was the o ring, but it turned out to be something on the timing cover popped off, cant remember what it was, i think some gasket/seal. Anyway I changed my t belt because it was soaked in oil.
Old Jan 7, 2008 | 12:07 PM
H22Honda98's Avatar
Default Re: H22 oil leak (es_squared)
i had the same problem, turned out to be cams seals....
Old Jan 10, 2008 | 12:18 PM
Colby71's Avatar
Tons of oil I have not ran it for the past fue days today i brought it like 1/10 of a mile and it is all over I will have pics tonight just have to resize them so it will not take so long to load up.
Old Jan 10, 2008 | 12:31 PM
Colby71's Avatar
Hey guys here are some pics decied I had time befor work.
FLAC- oil leaking right off it
Where it looks like it is comming from
Old Jan 10, 2008 | 04:47 PM
ne4spe's Avatar
i cant really tell where the oil could be coming from but i jus recently had a problem with oil LEAKS. i would check to see if your PCV valve is good first bcuz as it turned out it as that goin bad which caused all the excess pressure to leak out elsewhere. i had to change my valvle cover gasket my oil cooler o ring and my vtec oil pressure gasket b4 i found out that was the problem and my leak looked sounds similar to what you are describing because oil spun off everywhere off of my axle
Old Jan 14, 2008 | 11:07 AM
Colby71's Avatar
Turned out to be the screw you take out to alligne the balence shafts. I put a new one in and used some locktite.
H22Ej2
Sep 11, 2006 11:49 PM
evolvedAP1
Jun 29, 2006 01:15 PM
enigma94
Mar 31, 2005 05:56 PM
citrusdrop
Jul 24, 2003 09:00 AM
