Idle at 3k and throws TPS code(7) replaced it same thing. Any suggestions?
Im trying to help a buddy fix his dohc sol. It idels at 3k and throws tps code, we changed it for a new one and does the same thing. Anyone have any suggestions on what to do next?
did you reset your ecu? loosen the screws on the TPS and rotate it a little while the car is running and see if it changes anything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc »</TD></TR><TR><TD CLASS="quote">Did you calibrate the TPS?</TD></TR></TABLE> what would that be? and i dont think he reset his ecu ill let him know we did lossen it and try to play wtih it but it just idled higher.
you have to calibrate the TPS sensor by moving back and fourth. You need a voltmeter to mesure the voltage of the TPS. Check with Honda what the numbers are but you need a certian output at idle and a certian output at wide open.
iamhollywood[BRS]
Sep 21, 2006 11:12 PM
