IAC/throttle body problems
Old Jan 6, 2008 | 12:22 PM
boostcrx89's Avatar
Default IAC/throttle body problems
the car starts and will shut off if gas is not applied.... the ecu is reading the number 14 code...i tried 3 different IAC's and still showed the same code but all the iac's were used and not to sure if they worked or not. Also the guy i got the car off of ported the throttle body himself... is that a problem?
Old Jan 6, 2008 | 01:06 PM
GhostAccord's Avatar
Default Re: IAC/throttle body problems (boostcrx89)
Has the car run properly since he did his DIY Throttle Body porting job?
It could be the throttle body if he didn't get a properly sized butterfly for the porting that he did. Or if it is out of round it will let too much air passed the throttle plate/butterfly.
Do you know if he actually ported the throttle body to make it larger at the butterfly or did he just make the taper into the butterfly wider and keep the same size throttle opening?
Did you reset the ECU each time you replaced the IAC valve for testing?
Old Jan 6, 2008 | 02:39 PM
boostcrx89's Avatar
Default Re: IAC/throttle body problems (GhostAccord)
i do not know if it ran properly...but i know it was put on because of the same problem..
looks like the port is up to the butterfly...
we didnt reset it but i will try that out, i will post after i know.
Old Jan 6, 2008 | 04:30 PM
sorrule's Avatar
recheck your plugs maybe, make sure your TPS and Map ones are mixed around. It won't throw a code if they are mixed up. Check the butterfly plate fitment. Clean spray inside of IACV, it may be sticking? Check fuel pressure, may have a bad FPR? Does is sound like it's not running on all four cylinders? Check firing order/timing. I don't just throwing ideas out there.
Old Jan 6, 2008 | 04:52 PM
boostcrx89's Avatar
ok i reset the ecu.. still reads code 14... i double checked all plugs and plug wires. its running on all four and its getting fuel. if i keep my foot on the gas it runs like a dream but as soon as i let off it shuts off... so i will switch the two plugs and see if that helps any.
Old Jan 6, 2008 | 05:05 PM
civicb18Tkid's Avatar
he just called me screaming like a little girl because its fixed lol
Old Jan 6, 2008 | 05:07 PM
boostcrx89's Avatar
sorrule your my hero just to let you know.....
Old Jan 6, 2008 | 05:46 PM
sorrule's Avatar
yep happens a lot stupid plugs haha
todaV-TecEF8
Mar 24, 2009 01:53 PM
boostcrx89
Jan 6, 2008 07:54 PM
FATninja19
Jun 26, 2006 10:51 PM
methodz55
Apr 9, 2005 07:34 AM
