ONEOFFACCORD CB7 WIRE TUCK & ENGINE BAY SHAVING
Old Jan 6, 2008 | 12:18 PM
oneoffaccord's Avatar
Default ONEOFFACCORD CB7 Build-up thread
Ive been looking at all these engine bays with these wire tucks and shaved bay for sometime now. So i decided to tackle it.
Well heres a brief history on the car: picked up the car up the car in north jersey an auciton back in 2000. been thru alot of motors, transmissions, different styles and etc.
Enough talk on the car more on this build. will be doing a full wire tuck, engine bay shave, suspension powdercoated. new parts and so on. deleting somethings "couch, couch, P/S, couch". get a few new things in the bay. refreshing the motor with new things, theres alot more but for right now ill update this as mush as possible. heres a few pics. well i started this build about a month ago, so have alot more pics stored.
Modified by oneoffaccord at 1:38 PM 1/6/2008
Modified by oneoffaccord at 7:33 PM 1/6/2008
Modified by oneoffaccord at 6:36 AM 5/21/2008
Old Jan 6, 2008 | 12:19 PM
Default Re: ONEOFFACCORD CB7 WIRE TUCK & ENGINE BAY SHAVING (oneoffaccord)
Old Jan 6, 2008 | 12:20 PM
Old Jan 6, 2008 | 12:35 PM
KYLE.'s Avatar
GL with the rest of it
Old Jan 6, 2008 | 12:48 PM
Hater's Avatar
Default Re: ONEOFFACCORD CB7 WIRE TUCK & ENGINE BAY SHAVING (KYLE.)
Here is the wire-tuck I'm doing on my home network...
Old Jan 6, 2008 | 06:30 PM
Default Re: ONEOFFACCORD CB7 WIRE TUCK & ENGINE BAY SHAVING (Hater)
Modified by oneoffaccord at 5:13 AM 1/7/2008
Old Jan 6, 2008 | 06:32 PM
taking more **** out of the engine bay today. **** looks all naked and what not. i cant believe that i've done this to my car. but the end result is well worth it
Old Jan 7, 2008 | 04:04 AM
heres my brand new master cylinder. i completely stripped, primed, painted and cleared the brake booster. this **** right here makes me really happy :bouncy:
Old Jan 7, 2008 | 04:06 AM
also got my engine/fuse box harness all done. both a/c and heater blower boxs sit perfectly with all the wires in he way. done for tonite. have to be up at 6am for work :angry:
Old Jan 7, 2008 | 04:12 AM
408wdy's Avatar
nice progress.. can't wait to see the end result
Old Jan 7, 2008 | 04:14 AM
Default Re: ONEOFFACCORD CB7 WIRE TUCK & ENGINE BAY SHAVING (408wdy)
thanks alot. ive gotten alot ruther with everything. just dont want to post too many pics.
Old Jan 7, 2008 | 04:17 AM
if anyone has any tips feel free to help out.
Old Jan 7, 2008 | 04:19 AM
power folding mirror and speaker wires ran with the O.E. wiring setup( through the chassis to the door.
These are for the jdm power folding mirrors and speaker wiring. ive found this so i had to buy it. going to redo my wiring as u can see above, it dont look that good to me. makes connecting and disconnecting alot easier if i ever have to take off the doors :tu:
Modified by oneoffaccord at 3:15 PM 6/29/2008
Old Jan 7, 2008 | 04:28 AM
408wdy's Avatar
looks like you're doing very well.. only tip i can give you is to use heat temp rated electical tape.. if you use regular tape it will expand and get sticky in the heat as time progresses..and try not to use so much.
Old Jan 7, 2008 | 04:29 AM
clutch and brake line, the long one is the clutch line and its too long, have to go get it remade
Old Jan 7, 2008 | 04:30 AM
finally my interior wiring is all done. all my strobe and neon lights are all one harness. my jdm power folding mirror and speaker wiring is all one harness. all my guages are all one harness. SO NO MORE WIRING MESS :bouncy: heres how my jdm power folding mirror and speaker wire harness looks going thru the door. only have driver side pic but its the same way on th passenger side.
the 6-pin plug
all taped thru the factory harness
this is the rest of the harness that plugs in the the factory relay for the power folding mirror.
Old Jan 7, 2008 | 04:44 AM
.just need a welder to fill in some holes then go from there. so heres the updated pics.
Old Jan 7, 2008 | 06:18 AM
Drag_On's Avatar
Well done man - going to look hot.
Is that supersonic blue?
Old Jan 7, 2008 | 06:40 AM
hybrid93SIvic's Avatar
Default Re: (Drag_On)
cb7 bay's are so cluttered...this will look great!
Old Jan 7, 2008 | 07:30 AM
RACEPAK's Avatar
Default Re: (hybrid93SIvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag_On &raquo;</TD></TR><TR><TD CLASS="quote">.
Is that supersonic blue?</TD></TR></TABLE>
looks like DAP,
Old Jan 7, 2008 | 07:57 AM
KidSenation's Avatar
Hope it turns out as good if not better than my boys...
&lt;/a&gt;
Goodluck.
Old Jan 7, 2008 | 04:07 PM
yes sir it sure is supersonic blue
Old Jan 7, 2008 | 04:13 PM
yea accords bays are cluster expletiveed indeed. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">
[QUOTE=KidSenation]Hope it turns out as good if not better than my boys...
&lt;/a&gt;
Goodluck.</TD></TR></TABLE> im going to try my best to get it as good as his, but its no competition on whos better. im doing it for me
Old Jan 7, 2008 | 04:18 PM
Default Re: (oneoffaccord)
finally got ahold of a welder today. sooo happy. welding all these small as whole is a pain in the ***. put it will be well worth it in the end :tu:
<FONT COLOR="Orange">THE WELDING JOB, BEFORE</FONT>
