GSR Misfires on Idle 95 Civic OBD1 Stock P72 Chip No Tune
Old Jan 6, 2008 | 11:46 AM
92EG8's Avatar
Default GSR Misfires on Idle 95 Civic OBD1 Stock P72 Chip No Tune
My EG with a GSR 95 OBD1 Swap has been misfiring since one day that my motor drank a bit of water . I have boughten new sparkplugs and new cap. I had the new spark plug with the old wire for bout 2 month and then I put some NGK blues.. The Misfire is nothing serious just annoying to here from the exhaust. It doesn't misfire through out the RPMS or at WOT .Just at about 800-1200 maybe less 1200. So what can I do test what is causing this misfire. Its bone stock motor with the 2nd Butteflys vacuum off and one of the PCV valves are the one that throw out air is blocked off from the pcv valve box and intake mani. Those are the only modifications that motor has. Any ideas on what can be causing this misfire if you need more information just post and ask thanks
Old Jan 6, 2008 | 12:10 PM
RIZOBIZERT's Avatar
Default Re: GSR Misfires on Idle 95 Civic OBD1 Stock P72 Chip No Tune (92EG8)
Could it be that you only notice the miss at low RPM's and yet it's still happening a high RPM's. Since the motor is spinning faster you may not notice the difference. I would do some basic checks just to make sure that you don't have other problems. I'd do a lead down check and a compression check. I would go back to basics and rethink things. What does the motor need to run? Compression, timing, fuel, spark and oxygen. Start with the basics and go from there. Good luck.
Old Jan 11, 2008 | 09:22 AM
92EG8's Avatar
Well I've held the accel. pedal to about 2000 RPMS steadly and dont hear any misfiring at all. Is there anyway to test or look at a spark plug and see if that maybe the probelm?
Old Jan 11, 2008 | 11:35 AM
speedooo's Avatar
Default Re: (92EG8)
side effect of running a little rich...not a big deal
Old Jan 11, 2008 | 11:38 AM
SkoundrelUSA's Avatar
cute little bastard
You sure you got the firing order correct?
Old Jan 11, 2008 | 12:42 PM
speedooo's Avatar
Default Re: GSR Misfires on Idle 95 Civic OBD1 Stock P72 Chip No Tune (SkoundrelUSA)
it would backfire when he tried to start it if he had the firing order screwed up
Old Jan 11, 2008 | 01:32 PM
Relic1's Avatar
Default Re: (speedooo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo &raquo;</TD></TR><TR><TD CLASS="quote">side effect of running a little rich...not a big deal</TD></TR></TABLE>
that would be my guess as well.
remove J1 and see if it remains.
Old Jan 11, 2008 | 01:37 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: (Relic1)
have you checked to see which cyl is misfiring...load the car down till it starts to miss and pull one by one the plugs wires out if it starts missing worse put that plug wire back in and go to the next till you find the one that doesn't change the miss use a pair of pliers with rubber grips and don't lean on the car or you will be in for a shock
Old Jan 12, 2008 | 11:48 AM
92EG8's Avatar
Ok my car does run rich that is a known fact could that be the cause for it?
Old Mar 16, 2008 | 02:11 PM
92EG8's Avatar
bump just got new sparkplugs still misfires nd i got a new chip AS well
Old Mar 16, 2008 | 04:46 PM
NoBrows's Avatar
it could be the coil or the moduale
Old Mar 16, 2008 | 06:51 PM
92EG8's Avatar
thats what i was thinking any sure way to test this??
Old Mar 17, 2008 | 08:34 AM
92EG8's Avatar
bump
Old Mar 17, 2008 | 08:53 AM
ArchEnemy's Avatar
Default Re: (Throwdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">have you checked to see which cyl is misfiring...load the car down till it starts to miss and pull one by one the plugs wires out if it starts missing worse put that plug wire back in and go to the next till you find the one that doesn't change the miss use a pair of pliers with rubber grips and don't lean on the car or you will be in for a shock </TD></TR></TABLE> Good info!
Old Mar 17, 2008 | 12:06 PM
NoBrows's Avatar
Default Re: (92EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92EG8 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i was thinking any sure way to test this??</TD></TR></TABLE>
power up the coil and see if it arks to test the coil look up specs and test it using ohm meter or a multimeter
Old Mar 31, 2008 | 01:28 PM
92EG8's Avatar
UPDATE: I got the ignition module brand new . Swapped it and IT STILL THE SAME MISFIRING!. I got less then a month old sparkplug wires and a couple months old cap ( didnt purchase a new rotor though) NGK Blues also a couple month old and still misfiring. I got a new chip and no difference. I pulled out plug by plug on the motor no luck on finding a cylinder that was misfiring. Experts what can this be ?
Old Apr 1, 2008 | 12:34 PM
92EG8's Avatar
bump...help
Old Apr 16, 2008 | 09:47 AM
92EG8's Avatar
bump
Old Apr 16, 2008 | 09:59 AM
92EG8's Avatar
vump
Crazy_1.8L
Feb 9, 2006 05:59 AM
FROSTDC2
16
Nov 7, 2005 07:39 AM
cadet
Nov 17, 2004 11:01 PM
Need4Boost
Oct 9, 2003 12:37 PM
Blown90hatcH
Jul 17, 2001 11:43 PM
