VW bus IRS tranny to h22?
Old Jan 6, 2008 | 11:29 AM
RIP V8s's Avatar
Default VW bus IRS tranny to h22?
like the titel says, i am in the process of hanging up my street hat for the dunes, and i am interested in purchasing a san rail. I am sue most of you know the common motor sets ups consist of VW motors, suburu, or LS v8s, but the are all mounted to a VW bus style tranny with numberous different types of adapters. i have seen the odyssey motors and swear a few b series motors too, was just wondering if anyone on here knows of any one building the adapter for a h22
thanks,
D
Old Jan 6, 2008 | 01:05 PM
Pyrorocketeer's Avatar
Default Re: VW bus IRS tranny to h22? (RIP V8s)
http://www.kennedyeng.com/
How do you plan on working around the fact that the h22 rotates counter clockwise, and not clockwise like the stock vw?
Old Jan 6, 2008 | 01:17 PM
RIP V8s's Avatar
Default Re: VW bus IRS tranny to h22? (Pyrorocketeer)
not sure, figured that i have seen some b motors with them so there has to be a way...
Old Jan 6, 2008 | 01:45 PM
slowgti's Avatar
if you grab the right tranny you can flip the ring gear around in the tranny.
Old Jan 6, 2008 | 02:18 PM
RIP V8s's Avatar
Default Re: (slowgti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowgti &raquo;</TD></TR><TR><TD CLASS="quote">if you grab the right tranny you can flip the ring gear around in the tranny.</TD></TR></TABLE>
do you know what tranny is needed with the specific ring?
Old Jan 6, 2008 | 02:43 PM
Default Re: (RIP V8s)
I think almost all old vw transmissions are symmetrical, so the ring gear can be flipped. there are a few problems with just flipping the ring gear strength-wise.
Old Jan 7, 2008 | 07:16 AM
Top Ramen's Avatar
Default Re: (Pyrorocketeer)
You can get that VW tranny built with a reverse ring and pinion. BTW, an NSX drive train is excellent for a rail, including the transmission.
Old Jan 7, 2008 | 09:31 AM
Default Re: (Top Ramen)
I'm pretty sure no one makes a reverse ring for any of the vw transmissions, and or early porsche....
I could be wrong tho. Where did you hear of this being done?
Old Jan 7, 2008 | 10:07 AM
89crxhf's Avatar
I have heard of this being done, but since i am not into early vw or sandrails i wouldnt know. There is a place local to me called Arizona transaxle exchange that specializes in early vw transaxles for sandrails you might try them there number is
602) 269-1444.
Old Jan 8, 2008 | 08:36 AM
quicksilver1689's Avatar
i ♥ snails
not too thread jack but i see all these v8 powered rails with awesome power but have never seen a 2jz powered or rb powered rail
Old Jan 9, 2008 | 03:29 PM
littleredhatch's Avatar
pm'd
Old Jan 9, 2008 | 06:50 PM
West Werks's Avatar
I've built a b-series rail. PM me if interested.
https://honda-tech.com/zerothread?id=1006776
Old Jan 11, 2008 | 09:41 AM
Brent L's Avatar
we've just flipped the ring gear..always worked for us
Old Jan 12, 2008 | 06:12 AM
Default Re: (Brent L)
and no problems with putting the load on the other side of the ring gear?
Everyone says that you'd have problems, and significantly weaken it, but I've never seen anyone that has actually tried it.
Old Jan 12, 2008 | 08:37 AM
dave@passenger's Avatar
I've had two bosses that have flipped the ring gear without issue, I have never done it myself.
Old Jan 12, 2008 | 10:47 AM
Top Ramen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pyrorocketeer &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure no one makes a reverse ring for any of the vw transmissions, and or early porsche....
I could be wrong tho. Where did you hear of this being done?</TD></TR></TABLE>
I've purchase two VW transaxles that were built for mid-engine cars and ran the opposite direction as stock. I thought they used a reverse R&P since that's how the builder referred to it, but perhaps they just flipped it. It was years ago, so I can't remember who built them, but it was one of the better known rail parts suppliers.
Old Jan 13, 2008 | 07:17 AM
just flipping the ring and pinion for a mid engine setup is ok, because your still loading the ring on the same side, but when you flip it, and run an engine the opposite way the tranny was designed for, then the ring gets loaded on the other side of the teeth, and it can stress it and possibly break teeth.
like when you bend a hardened piece of steel one way, then bend it the other, it will just snap, and not bend back.
Old Jan 13, 2008 | 09:39 AM
Top Ramen's Avatar
Ten seconds on Google found this:
http://www.transworks.biz/mendeola.html
Probably a good starting point, as they claim their reverse rotation R&P will handle high hp applications.
Old Jan 15, 2008 | 02:43 PM
RIP V8s's Avatar
what about k series motors? clockwise or no?
Old Jan 15, 2008 | 03:17 PM
cua0's Avatar
yes k-series turn clockwise.
Old Jan 15, 2008 | 09:50 PM
RIP V8s's Avatar
Default Re: (cua0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cua0 &raquo;</TD></TR><TR><TD CLASS="quote">yes k-series turn clockwise.</TD></TR></TABLE>
problem solved....
BergRacing21
Jan 12, 2006 03:43 PM
BaGGed HoNDa
Apr 22, 2005 06:09 PM
18gLUDE
Mar 2, 2005 03:45 AM
Siegfried
May 16, 2004 02:17 AM
streetspeed607
Apr 12, 2004 12:54 PM
