JDM H22a and Type S pistons
Old Jan 6, 2008 | 10:49 AM
H-EK22's Avatar
Default JDM H22a and Type S pistons
ok how do you you have a Jdm h22a type s engine or the base jdm h22a engine, theres a difference in HP??? also will adding type s pistons on the NON-type s increase performance?? and will the stock piston rings fit the type s pistons???? thanks
Old Jan 6, 2008 | 11:09 AM
RyanStevenPhillips's Avatar
Default Re: JDM H22a and Type S pistons (H-EK22)
adding type s pistons will increase your CR, so yes there will be an increase in power. (thats assuming you have a USDM engine)
Old Jan 6, 2008 | 11:24 AM
hybrid2007's Avatar
Default Re: JDM H22a and Type S pistons (RyanStevenPhillips)
It will help even if he has a JDM lump, and yes rings are the same.
Type S CR 11:1
JDM CR 10.6:1
USDM CR 10:1
Old Jan 6, 2008 | 11:49 AM
H-EK22's Avatar
Default Re: JDM H22a and Type S pistons (hybrid2007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2007 &raquo;</TD></TR><TR><TD CLASS="quote">It will help even if he has a JDM lump, and yes rings are the same.
Type S CR 11:1
JDM CR 10.6:1
USDM CR 10:1</TD></TR></TABLE>
Yeah its a JDM block...... is it really worth it cus i know that with aftermarket pistons you will have to sleeve the block and thats just to much money, plus you guys think that the jdm block with type s pistons will be enough compression with the Crower 3 cams or should i go with the Crower 2's???? thanks guys
Old Jan 6, 2008 | 12:06 PM
hybrid2007's Avatar
If i could go back and start my build over again i would have left the bottom end alone and just used a thinner head gasket/milled head and high comp valves to bump my CR just for the fact that it would be on the road by now. If your block is in good condition its not worth ripping your bottom end apart just for a .4 increase in CR IMO
On the cam side, what does Crower suggest?
Old Jan 6, 2008 | 12:13 PM
H-EK22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2007 &raquo;</TD></TR><TR><TD CLASS="quote">If i could go back and start my build over again i would have left the bottom end alone and just used a thinner head gasket/milled head and high comp valves to bump my CR just for the fact that it would be on the road by now. If your block is in good condition its not worth ripping your bottom end apart just for a .4 increase in CR IMO
On the cam side, what does Crower suggest?</TD></TR></TABLE> Well i dont think my block is bad but how can i find that out???? motor was imported from Jap. with like 50k on it from the same Company my buddy bought it from, Nagasaki
Old Jan 6, 2008 | 12:26 PM
hybrid2007's Avatar
Basically i mean if your motor is running well at the moment i wouldn't rip the bottom end apart just for a .4 increase.
Old Jan 6, 2008 | 12:28 PM
H-EK22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid2007 &raquo;</TD></TR><TR><TD CLASS="quote">Basically i mean if your motor is running well at the moment i wouldn't rip the bottom end apart just for a .4 increase.</TD></TR></TABLE> Yeah runs fine....So ill just spend the money on something that will give me more HP, any suggestions HYBRID2007
Old Jan 7, 2008 | 11:28 AM
hybrid2007's Avatar
If it was me i would spend the money on a good head build, custom header, and most importantly a good tune. Make sure you do lots of research aswell. I've bought and sold a couple of grands worth of stuff during my build which i wouldnt have had to do if i had been patient and spent more time researching in the first place.
Theres some great info in the FAQ thread
Old Jan 7, 2008 | 04:00 PM
ESP.net's Avatar
2nd that
Old Jan 7, 2008 | 08:40 PM
supramr2's Avatar
i'll have to agree with hybrid2007, i've done my research and there really isn't a point to take apart your bottom end if it still runs good...but definitely a good head build i.e. valvetrain, cams, etc. and a good tune is probably the best way to go
trooper0641
Feb 17, 2008 05:29 PM
DAGAME
Apr 18, 2006 12:00 PM
vtec420kingH22
Oct 14, 2005 06:45 PM
gen4h22a
Oct 25, 2003 01:51 PM
HondaH22A
Dec 15, 2002 09:21 PM
