Blower problems
The blower motor will not turn on at all on any setting. Therefore, I ruled out the resistor module. I took a voltmeter to the 2 prong plug going to the blower motor and got no voltage on any setting. If it is NOT the fuse (because im 99% sure it is not) what else could it be? Is there a relay I can try? Any other factors im missing?
I am totally lost here.
I had a blower motor and resistor go at the same time. No fan on any setting. Replaced the blower motor and the fan would come on the two highest settings. replaced the resistor and I was good to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT GUY »</TD></TR><TR><TD CLASS="quote">I had a blower motor and resistor go at the same time. No fan on any setting. Replaced the blower motor and the fan would come on the two highest settings. replaced the resistor and I was good to go.</TD></TR></TABLE>
Yeah but i tested the plug for current going to the motor and it did not have any power going to it on either prong.
Look for the 30amp fuse to be blown and check for power to the blower motor first (check for ground separate from the the other wire)
My guess is the fuse
SpeedSin
11
Dec 6, 2008 06:32 AM
