Weird problem with FUJITA CAI RSX-S
Old Jan 5, 2008 | 06:57 PM
idobref's Avatar
Default Weird problem with FUJITA CAI RSX-S
see this pictures
basically the damn pipe its in the way of that thing and i cant shift to 1/3/5 gear.
I already tried to move the pipe away from the thing and it seems to work for now
but I'm thinking that after a while the pipe might go back there
did anyone had that problem before ?
I'm just curious to know
thanks
Old Jan 5, 2008 | 07:44 PM
MITeggy17's Avatar
Default Re: Weird problem with FUJITA CAI RSX-S (idobref)
You need to adjust the brackets pretty much. It would've been best if you had installed it in 5th gear to make sure you cleared it, but that won't really help. Play with it for a little while.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rEDlinEDc5;9930520 &raquo;</TD></TR><TR><TD CLASS="quote">
The intake piping was also hitting the shifter linkage because somebody went inside the car during the install and took it out of 5th gear since I put it in 5th before the install. So I had to loosen everything up again and make room for the shifter linkage. I could only muster up about 1cm space between the shiftlinkage and the intake pipe*pics*.
Also make sure that the bracket that hooks up to the vibration dampener is connected. It will free up a lot of space :
This is what it looks like in 5th gear:
Old Jan 7, 2008 | 10:07 AM
ALLmotorTYPES's Avatar
looks like you intalled it wrong! I put my in, and it never caused that problem. Yours looks way off?
miahjera04
Transmission & Drivetrain
Jul 2, 2016 07:01 PM
lumnite
Dec 9, 2009 06:29 PM
dome
Jul 2, 2007 05:34 PM
Willz
Feb 4, 2007 12:11 PM
Evoluti0n
Feb 15, 2004 08:42 AM
