Weird TPS problem, fresh ZC swap
Old Jan 5, 2008 | 06:22 PM
crex23's Avatar
Default Weird TPS problem, fresh ZC swap
I have a 89 CRX DX and I swapped in a sohc ZC, now I'm getting a CEL code 7 for the TPS. The car is an automatic using a PS9 ecu, and I had already done a MPFI swap long before I got the ZC motor, and I had no codes before I did the ZC swap.
The motor came OBD1 and I used the intake manifold, throttle body, and fuel rail that came with the motor. I had a distributor that was pretty new, so I just used it and my old injectors and stayed OBD0 for simplicity. I also used my old OBD0 engine harness.
Now the car runs perfectly, idles perfectly but I'm getting the code 7. I tried adjusting the TPS using my multimeter, but the highest value I could get was .32 volts. I've tried swapping my old TPS but no luck. I even tried cleaning the FITV after reading a post where that cleared up a guy's code 7.
I'm not sure what else to try. Like I said the car runs perfectly, but I don't like seeing that check engine light on the dash. Any help is appreciated!
Old Jan 6, 2008 | 08:28 AM
crex23's Avatar
Default Re: Weird TPS problem, fresh ZC swap (crex23)
Any suggestions?
Old Jan 6, 2008 | 12:56 PM
24TEN's Avatar
PHANTOM MENACE
I think we flipped two wires on the TPS when we converted MPFI on my friend's old hatchback. Did you do that?
Old Jan 6, 2008 | 02:07 PM
crex23's Avatar
Default Re: (24TEN)
Yeah I did that. I didn't have any CEL's before I put the ZC motor in.
DEADLYACURACCY
Mar 9, 2006 04:57 PM
DJ_SaNdOz
11
May 28, 2003 08:34 PM
Pcart
Oct 17, 2002 05:59 AM
xtremcrx77
Oct 9, 2001 08:08 PM
