D16 Build
I am planning to do a little bit of stuff to my D16 for fun. Not looking for serious power so keep the flames away.
I am thinking of 2 plans right now...not sure which, so any advice/opinions would be appreciated. This project will be with a D16Y8
Option 1:
DIY ITBs
Crower Stage 1
Skunk2 Cam gear
DC 4-2-1 Header
2.5 exhaust (thinking about kteller piping, with es oval muffler)
OBD2 to OBD1 Conversion harness
P28 ecu tuned on crome
Options 2:
B series throttle body
"Whale *****" intake
DC 4-2-1 header
2.5 exhaust(thinkg about kteller piping, with es oval muffler)
Crower stage 2 cam (will i need to run the crower retainers and springs if were to keep it under 7200RPM?)
^^^If i have to run the retainers and springs, i might just go with a stage 1 cam instead
Skunk2 Cam hear
OBD2 to OBD1 conversion harness
P28 tuned on crome
What do you guys think? This will be my first build. TIY.
Have a nice day
Option 1:
DIY ITBs
Crower Stage 1
Skunk2 Cam gear
DC 4-2-1 Header
Options 2:
DC 4-2-1 header
Skunk2 Cam hear
P28 tuned on crome
Have a nice day
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FW_EJ8 »</TD></TR><TR><TD CLASS="quote">I am planning to do a little bit of stuff to my D16 for fun. Not looking for serious power so keep the flames away.
Option 1:
DIY ITBs
Crower Stage 1
Skunk2 Cam gear
DC 4-2-1 Header
Options 2:
DC 4-2-1 header
Skunk2 Cam hear
P28 tuned on crome
Have a nice day
For your first option, i don't think diy itb's is the way to go. I think you will see more benefits from the itb's if you had some head work done. You can expect more gains from an after market IM and even more if you choose to bore it out. Also, what injectors do you plan on using?
for your second option, if you plan on using the Crowers stage 2 cam you MUST upgrade your VT. Your stock D series VT will not be able to handle the aggressiveness of that particular cam.
Eventhough you don't plan on revving that high, it is better to be safe than sorry. And doing it right the first time wont hurt you or your pockets.
My opinion, if you were on a budget. Go w/ option 1, ditch the itb's and invest the moeny in an aftermarket IM. Stick with either stage 1 or stage 2 cams and use the "whale *****" Keep in mind, it will be smart to upgrade the VT. Keep the skunk2 cam gears, and invest in a better clutch to deliver power. As far as your ecu, you should be ok there. AGAIN, this is my opinion. Good luck with the build
Option 1:
DIY ITBs
Crower Stage 1
Skunk2 Cam gear
DC 4-2-1 Header
Options 2:
DC 4-2-1 header
Skunk2 Cam hear
P28 tuned on crome
Have a nice day
</TD></TR></TABLE>For your first option, i don't think diy itb's is the way to go. I think you will see more benefits from the itb's if you had some head work done. You can expect more gains from an after market IM and even more if you choose to bore it out. Also, what injectors do you plan on using?
Thanks for your response, helps a lot. Keep in mind, i AM on a budget.
So what i am thinking now is..
-"whale *****" intake (already have)
-dc header (already have)
-2.5" exhaust
-skunk2 IM
-skunk2 cam gear
-crower stage 1 cam
-p28 ecu tuned on crome
-stage 2 clutch (don't know what is good out there for a decent price)
-2.5" exhaust
-skunk2 IM
-skunk2 cam gear
-crower stage 1 cam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FW_EJ8 »</TD></TR><TR><TD CLASS="quote">Thanks for your response, helps a lot. Keep in mind, i AM on a budget.
-2.5" exhaust
-skunk2 IM
-skunk2 cam gear
-crower stage 1 cam
-stage 2 clutch (don't know what is good out there for a decent price)</TD></TR></TABLE>
you can save a little more money by going w/ a blox IM. But if you search, you can probably find a used sk2 IM for a decent price. But a new blox IM is anywhere between 100-150 new. **This isn't a "blox vs. Sk2" thing**
-2.5" exhaust
-skunk2 IM
-skunk2 cam gear
-crower stage 1 cam
Sell the DC and take the money that would go into the ITB's and get an SMSP. I'm willing to bet you see better gains from the header than you do the Crower 1 cam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">Sell the DC and take the money that would go into the ITB's and get an SMSP. I'm willing to bet you see better gains from the header than you do the Crower 1 cam.</TD></TR></TABLE> My buddy didnt see much gain on the crower 1 on stock valve train.... even after the tune he gained 7-8 horespower on the crower 1, with the smsp header you'll be looking at 10-14 hp gain after tuning
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FW_EJ8 »</TD></TR><TR><TD CLASS="quote">hmm makes me think about jsut getting a stage 2 and upgrading the valvetrain.
an SMSP runs about $500? correct me if i am wrong</TD></TR></TABLE>
Youre wrong.
Youre wrong.
i think i have made my mind about the cam i am going with. crower stage 2 and will be upgrading retainers and springs.
I am going to go with a b series TB. should i just port match my stock mani? or get a blox mani?
i will keep you guys updated, although this is going to take me a while. being 17, i dont make a lot of money
thanks for your guys help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FW_EJ8 »</TD></TR><TR><TD CLASS="quote">i think i have made my mind about the cam i am going with. crower stage 2 and will be upgrading retainers and springs.
</TD></TR></TABLE> Instead of getting a B series TB an port matching it or buying the blox intake mani, waste your money in something else more usefull like port an polish your head and a valve job, that will run you about $500-600 and youll see way more power gains than the Bseries TB with the blox intake mani that probably will run you around $350 and wont see real gains...
$350?
a brand new blox mani is no more than $200 for sure. i can probably find one for aournd $150 and a b series tb is around $60 or so, depending which one i get.
$60...Stock B TB....yeah, thought you buyng blox or skunk.....aftermarket intake manifolds on stock head...you really dont see much gains for the money you gonna pay, lucky 5-7 hp, on stock head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-EK22 »</TD></TR><TR><TD CLASS="quote">$60...Stock B TB....yeah, thought you buyng blox or skunk.....aftermarket intake manifolds on stock head...you really dont see much gains for the money you gonna pay, lucky 5-7 hp, on stock head</TD></TR></TABLE>
even with the crower stage 2 street cam? going to run the springs and retainers amd skunk2 cam gear too if that matters
SlammedDC2
Apr 22, 2007 08:07 PM
JDMcivicRacing
Aug 1, 2005 07:40 AM
