full-race radiator fitment question
Old Jan 5, 2008 | 12:58 PM
yz125rider21's Avatar
Default full-race radiator fitment question
ok guys I just finally got time to put it in my car and when I did I notice that the oem bracket to hold the radiator dont go low enough to where the nipple is on the radiator and was wondering if someone makes brackets for that and also what you use on the bottom the radiator from not moving cause I dont know if i was suppose to recieve some rubber gromets or not...its in my crx and I have the full-race bar and full-race radiator just so I dont get replys asking the set-up.....thanks in advance and will add a pictures tonight when I get my camera if you dont understand what I am saying.
Old Jan 5, 2008 | 03:51 PM
GSX 4G63T's Avatar
Default Re: full-race radiator fitment question (yz125rider21)
http://passwordjdm.com/Innovat....aspx
Old Jan 6, 2008 | 12:20 PM
thanks was trying to member where i saw that last...also what about the bottom of radiator does it just sit metal to metal or should I put 2 rubber bushings down there so it wont damage the radiator??
Old Jan 6, 2008 | 01:25 PM
dr_latino999's Avatar
Default Re: (yz125rider21)
I have my radiator sitting metal to metal in my FR setup, seems fine. The radiator really doesn't move around that much once the pressure in the hoses go up.
Old Jan 6, 2008 | 05:44 PM
but what tab style you have on the bottom of your radiator cause mine on the full-race page is diff, they have lil round cups on the bottom of the radiator mine has t nipples like the top one for the mount. just wanted to see if its the same thanks.
Old Jan 6, 2008 | 09:28 PM
crispynuggets's Avatar
I used the rubber mounts that you find on the bottom of the stock radiator. The same thing Full-Race uses in the picture!
Old Jan 6, 2008 | 09:38 PM
bump for more answers
Old Jan 7, 2008 | 12:48 AM
slow ass si 1's Avatar
I just cut the rubber out of the stock tabs and put them in the holes on the full-race bar, that works great for me.
Old Jan 7, 2008 | 03:48 AM
slywfbpsi's Avatar
Default Re: (slow *** si 1)
The rad mounting kit from here http://www.etdracing.com/8891.html wouldn't work?
Old Jan 7, 2008 | 05:57 PM
Default Re: (slywfbpsi)
NOT LOOKING FOR THE LOWER MOUNT ONLY TOP.
Old Jan 7, 2008 | 06:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">NOT LOOKING FOR THE LOWER MOUNT ONLY TOP.</TD></TR></TABLE> No need to get loud I'm not using a top mount, and my radiator has not moved an Iota thanks to the hoses. I probably should fab something up.
Old Jan 7, 2008 | 07:17 PM
sorry man...was doing paper-work for my company and have to use all caps ....didnt see that till you said that but ok I fab something up then I guess.
Old Jan 7, 2008 | 08:12 PM
STREETWERKZ's Avatar
that innovative piece is pretty nifty.
Old Jan 7, 2008 | 08:20 PM
crx2nr822's Avatar
Default Re: (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">that innovative piece is pretty nifty. </TD></TR></TABLE>
Havent heard that word in a while, "nifty"
Old Jan 7, 2008 | 10:43 PM
Default Re: (crx2nr822)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx2nr822 &raquo;</TD></TR><TR><TD CLASS="quote">
Havent heard that word in a while, "nifty" </TD></TR></TABLE>
yeah, it's making a comeback. all the kr-x guys are doing it.
Old Jan 7, 2008 | 11:42 PM
I just use the stock top mout for mine and its works great. I just bent it down a bit so that the rad cap would clear it.
aasaa666
Oct 22, 2007 08:15 PM
MiracleWhip
Apr 28, 2007 11:38 AM
umar456
Dec 5, 2002 12:36 PM
