90 integra speedo cable
Old Jan 5, 2008 | 11:26 AM
anthony90si's Avatar
Default 90 integra speedo cable
is the cable from auto and manual . the same? and what kind of a job is it to replace? thanks
Old Jan 5, 2008 | 02:17 PM
HONDRETTI's Avatar
Default Re: 90 integra speedo cable (anthony90si)
yup its the same... just disconnect both ends (remove the cluster, disconnect clip; remove boot, unplug from tranny) (also remove plug at the firewall) now take your new cable and duct tape it to the old one from inside the car...have someone pull the old one from the engine bay and feed the new one through the fire wall...reconnect, re-install cluster
Old Jan 5, 2008 | 02:20 PM
HONDRETTI's Avatar
Default Re: 90 integra speedo cable (HONDRETTI)
heres a walk-through on how to remove the cluster....good luck!
http://www.g2ic.com/tegtips/interior/21.html
Old Jan 6, 2008 | 10:41 AM
ah cool thanks dude.!!!
THE *FOB* MOB
Nov 16, 2016 12:28 PM
93grayeg
May 20, 2011 10:35 PM
crxagogo
11
Apr 8, 2003 08:31 AM
xXx Justin xXx
Oct 28, 2002 07:34 PM
