No spark on GSR Swap
Old Jan 5, 2008 | 11:16 AM
allmotorgsrcivic's Avatar
Default No spark on GSR Swap
I have basically ran through the list and so far still cant fix the problem. heres whats going on
No spark obviously,
1. Changed plug wires
2. Changed Dizzy
3. Changed engine harness
4. Changed ECU's
5. Changed Ingnition Harness
6. Changed Main Relay.
fuel pump is priming but i am getting no spark. checked the voltage going to the ecu and its good. checked if i was getting power to the dizzy and i am. i also noticed that the check engine light never goes off when you first turn the key on so i think the ecu is not turning on( i think). i know the ecu is getting power because i checked so what else could it be. i have the same problem and i have tryed multiple ecus.
Old Jan 5, 2008 | 11:30 AM
Wannabe JDM's Avatar
this may sound stupid. dont get mad at me for suggesting it. ive done this twice now. check your grounds. haha.
Old Jan 5, 2008 | 11:45 AM
pdotjones's Avatar
Default Re: (Wannabe JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wannabe JDM &raquo;</TD></TR><TR><TD CLASS="quote">this may sound stupid. dont get mad at me for suggesting it. ive done this twice now. check your grounds. haha.</TD></TR></TABLE>
i had the same problem...... grounds pwnd me!
Old Jan 5, 2008 | 12:09 PM
Cza_EM1's Avatar
Default Re: (pdotjones)
x3 on the grounds.
Old Jan 5, 2008 | 12:21 PM
pdiggitydogg's Avatar
I'll suggest grounds too...BUT I will also say that you check the continuity between all 3 - Not only at each terminal, but at their respective wires, to the ecu, to each other and to the chassis.
Check for breaks in the wiring (that killed me recently - Terminals were all grounded, but the wiring in the harness was broken so it didnt have continutiy to the ecu)
Your ecu ground @ the thermostat is composed of 2 terminals together...be sure neither of those wires has come loose/broken
Old Jan 5, 2008 | 02:41 PM
Default Re: (pdiggitydogg)
i checked the grounds in the engine bay and i checked to see if the ecu was getting good power using the chassis as a ground and using the ground wires in the harness. i am at a loss here and i cannot figure this problem out. any help???
Old Jan 5, 2008 | 02:54 PM
you are grounding the spark plug threads when youre checking for spark...right?
Old Jan 5, 2008 | 03:08 PM
i use a screwdriver when i check for spark. i also noticed that when i turn the key forward the check engine light does not flash at all. i think the ecu is not turning on at all. i also checked for spark using the spark plug and grounding it. still nothing
Old Jan 5, 2008 | 04:46 PM
Default Re: (allmotorgsrcivic)
i starts sometimes now after i changed the dizzy back to the old one. i think that from messing around so much i might of messed up the other one i had. problem is the car will not always start and it will not go past 2k when it is running. now i got to find the reason its doing that. by the way. i did all this using the p28 ecu. i am going to wait until everything is running good before swapping over to the p72. an advice on what to do about it not going past 2k would be appreciated. i think its because the tps sensor is missing one prong.
Old Jan 6, 2008 | 07:38 AM
efking1985's Avatar
bump for my car someone help us out
Old Jan 6, 2008 | 07:56 AM
Is the dizzy fully seated when you install it - you can have it 180 off, but it wont sit flush.
Have you checked the coil and icm?
What is your fuel pressure?
Old Jan 6, 2008 | 08:02 AM
efking1985's Avatar
but what would be the problem why it wont go over 2k
Old Jan 6, 2008 | 08:11 AM
A cel - damaged tps is obvious
Ignition problems
Clogged cat
others crap.....
Old Jan 6, 2008 | 08:17 AM
efking1985's Avatar
oh ok
Old Jan 6, 2008 | 11:35 AM
efking1985's Avatar
Default Re: (efking1985)
bump
Old Jan 6, 2008 | 12:37 PM
efking1985's Avatar
up
Old Jan 6, 2008 | 12:53 PM
schardbody's Avatar
make sure the TPS and MAP plugs arent swapped. the TPS should have a red wire, the IACV wont. this will cause the CEL and not rev.
Modified by schardbody at 7:45 PM 1/6/2008
Old Jan 6, 2008 | 12:54 PM
You said the tps is missing a prong....Id bet money on that being half of this whole ordeal
Old Jan 7, 2008 | 07:47 AM
efking1985's Avatar
it might be the problem
Old Jan 8, 2008 | 09:39 AM
efking1985's Avatar
bump
Old Jan 8, 2008 | 03:20 PM
no cat on right now so thats not it. i would bet money that its the tps sensor. the are plug in to the right sensor( not swapped). dizzy is seated correctly. i think it might also need another main relay as i dont hear it turn on every time.
zeusdavis
30
Nov 6, 2019 05:50 PM
CivicCpeEX
Jul 11, 2010 07:59 PM
spooncivic01
Feb 17, 2008 11:29 AM
ek4ferrio
Jun 3, 2007 02:59 PM
filip-s
Oct 26, 2006 07:22 AM
