Flashing CEL?...I tried to search
Old Jan 5, 2008 | 09:36 AM
EKstacy's Avatar
Default Flashing CEL?...I tried to search
My girlfriend has a 99 ex with the stock D16y8. She kows nothing about cars, and her car is in bad shape. I checked the oil yesterday and it was way below the bottom line, so i topped that off. She has had a flashing CEL for a while now and I dont know whats wrong. I tried to run the codes and it said nothing was wrong. What could it be?
Old Jan 5, 2008 | 09:45 AM
crazyguy's Avatar
Default Re: Flashing CEL?...I tried to search (EKstacy)
did u run the CEL check while the car is at idel or when CEL is flashing ?
Old Jan 5, 2008 | 09:52 AM
EKstacy's Avatar
Default Re: Flashing CEL?...I tried to search (crazyguy)
no, i just tried it with the car off but the switch on. Thats what the code reader says to do.
OMGWTFBBQ!'s Avatar
I believe when the CEL is flashing its an indication of cylinder misfire, but you should also be throwing a code that tells you which cylinder(s) are misfiring, as well as a Multiple Cylinder Misfire code if there are 2 or more cylinders misfiring. That happened in my 97 EX, but it would only flash for a bit then stay on, when we read the codes I had a misfire code for every cylinder, and the multiple cylinder misfire code.
Old Jan 5, 2008 | 10:16 AM
EKstacy's Avatar
Default Re: (OMGWTFBBQ!)
Well thats what i was thinking. It sure runs like its misfiring. I think it just may be in dire need of a tune up. I may try to pull the codes again with it running. What did you do to fix your problem?
Old Jan 5, 2008 | 04:41 PM
OMGWTFBBQ!'s Avatar
Had it dyno tuned. It was misfiring because the engine had been built and converted to manual with an automatic ECU, that poor thing had no idea what was going on, it was always in limp mode.
jwagner
Engine Management and Tuning
Apr 8, 2012 07:38 PM
civicb16eg
Jan 5, 2010 01:23 PM
AamirCWITR
Jun 25, 2003 01:47 PM
