Suspension & Brakes Theory, alignment, spring rates....
Koni disassembly question
Old Jan 4, 2008 | 06:11 PM
isumase's Avatar
Default Koni disassembly question
A little history first, I bought my car with Koni yellows with stock em1 springs and strut mounts/tophats.
I recently purchased ground control coilovers and gc tophats for the front for my em1. My question is, when removing the upper retaining nut at the top of the strut shaft, how do i hold the shaft in position for removal of the nut. I know on the factory unit, an allenhead key is used to hold it still, but on top of the Konis, all it has is the adjustment tip.
Ive searched and read all the install guides but cant find out how do I hold the shaft on the Koni's still for removal of the retaining nut without damaging it with vicegrips or something of the sort?
Old Jan 4, 2008 | 06:31 PM
slammed_93_hatch's Avatar
Default Re: Koni disassembly question (isumase)
i always have used an impact to get them off. I am not sure if this is common place though.
Old Jan 4, 2008 | 06:45 PM
isumase's Avatar
Default Re: Koni disassembly question (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">i always have used an impact to get them off. I am not sure if this is common place though.</TD></TR></TABLE>
That is one option, unfortunately, I will be doing this project at home without the use of air tools since at work, Honda dealership, I'm on limited time to finish it and would like to be able to take my time and relax and do it right and not rush.
Anyone else?
Old Jan 4, 2008 | 07:22 PM
DrSeuss's Avatar
If you look closely at the Koni, there's a hex head on top. I think it's 8mm but it's been a while. If you stick on wrench on there, it'll keep the shaft from turning. Then you can use another wrench to loosen the jamb nuts.
If that doesn't work, you can try a strap wrench but you'll need a friend to pull it tight while you brake the jamb nuts free.
Old Jan 4, 2008 | 07:42 PM
isumase's Avatar
Default Re: (DrSeuss)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrSeuss &raquo;</TD></TR><TR><TD CLASS="quote">If you look closely at the Koni, there's a hex head on top. I think it's 8mm but it's been a while. If you stick on wrench on there, it'll keep the shaft from turning. Then you can use another wrench to loosen the jamb nuts.
If that doesn't work, you can try a strap wrench but you'll need a friend to pull it tight while you brake the jamb nuts free. </TD></TR></TABLE>
So if I'm understanding you correctly, what you're saying is just above the threaded section at the top, and just below the tab for the adjustment ****, the threaded area is cut off and theres a hex head to hold onto?
Old Jan 5, 2008 | 03:44 AM
isumase's Avatar
Default Re: (isumase)
Old Jan 5, 2008 | 05:08 AM
DrSeuss's Avatar
If you look closely in this picture, you'll see the flat sides for a wrench just above the threaded portion.
Old Jan 5, 2008 | 06:21 AM
isumase's Avatar
AWESOME!!! Thanks for the help man. Never even noticed that.
mitchell_2kSiR
Suspension & Brakes
Feb 28, 2010 01:39 PM
beanbag
Suspension & Brakes
Apr 14, 2008 01:43 AM
.I.Need.Money.
Suspension & Brakes
31
Feb 1, 2007 09:24 PM
integra DC4
Feb 15, 2006 06:22 AM
QualityMaterial
Suspension & Brakes
Nov 22, 2005 01:51 PM
