Problem, which axle? teg b16
ok i have a 94 4 door teg with a b20 with ls trans right now. I bought a 2000 Si trans (b16) that i plan on putting in tomorrow, i bought a new axle for an ls teg is that the axle that i need or do i need something different? I have an ls intermediate shaft. let me know asap its 9:30 at night and i think i may have bought the wrong axle for a big job i was gonna start tomorrow morning early!!! Help!!! Thanks
Thank You Honda-Tech!!! I probably had one of the easiest questions on the board and nobody could answer it in the time provided. This site is really going down the hole, it was good 2 years ago!
thank you they worked just fine but now i'm having a starter issue, anybody know if i'm supposed to be using a different starter with a b20 block and a s4c (si) trans?
Here is the post about it: https://honda-tech.com/zerothread?id=2192375
Basically i thought that i may need a different starter with the swap but i'm not sure. The starter is clicking, I even pulled it off the trans to see if it was turning and it is but it doesn't seem to be catching the flywheel. I need help?
Black4thgenEF
Mar 21, 2006 02:56 PM
Puffwheat
Jan 21, 2004 07:55 AM
