Fidanza flywheel torque specs?
I have a 95 integra Ls and I bought the fidanze 7.5lb flywheel. In the instructions it states that the torque should be more than factory specs because the aluminim expands twice as fast as the crank so it need sto be tighter for the tolerances. I believe the factory spec is 78ft lbs. I was wondering if what everyone torqued theirs down to. Thanks in advance
The instructions from Fidanza's site state:
Follow the OEM specifications for the torque and replacement of the flywheel to crank bolts and clutch mounting bolts.
Jk_DC2
Feb 17, 2009 10:40 AM
madswapper
May 1, 2005 05:01 PM
