Valves hitting pistons
.Ok so I have an LS-V with GSR head/cams that I got and took it apart because was not sure of the condition of the motor. When the head came off I can see were the Intake valves were hitting the pistons. There is a perfect grove on all the pistons. The valves look fine as far as I can tell. It had the stock head gasket also. My question is why are the valves are hitting the pistons. I thought there should be more clearance.
good thanks i didnt even check that before i ripped it apart but it did have adjustable cam gears. Makes sence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4u831 »</TD></TR><TR><TD CLASS="quote">are you sure it's not the valve reliefs on the pistons.....?</TD></TR></TABLE>
thats what i was thinking
No the marks are on the valve reliefs. Almost like the vale relieves were to small or some thing. I really think that it was the cam timing. Also the pistions say PR4 the 0.8 Never seen the 0.8 on a piston before.
there should be tabs on three sides of the cylinder head. place a straight edge and see what feeler guage can you fit in there.
this tells you how much the head has been surfaced/decked.
i think piston to vlave clearance is somewhere near 150 thousandths so even a head milled .050", it should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">valve reliefs need to be cut to fit the larger valve face of the gsr head. especialy if you are using a higher lift cam. and clay the motor to make sure they don't hit </TD></TR></TABLE>
DOHCter is correct in this instance.
That is a PR4, a stock LS piston. The intake valve on a stock LS head is 2mm smaller than the VTEC ones. That groove was worn by a bigger valve trying to fit in a smaller area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MoonScryer »</TD></TR><TR><TD CLASS="quote">
That is a PR4, a stock LS piston. The intake valve on a stock LS head is 2mm smaller than the VTEC ones. That groove was worn by a bigger valve trying to fit in a smaller area.</TD></TR></TABLE>
Again, both correct!
sometimes they will clear depending on the deck/head castings, but most times they will hit even with stock cams. thats why claying the motor is best. if you don't want to cut the pistons (which i've seen many times by my shop) you can do like me, and buy some RS pistons with an itr dome height and larger valve reliefs. but i have a b20 block. or you can get actual itr pistons. remember to change the rod bolts for a set of arp's and you can rev to 8500 all day long with the stock rods if they are already straight.
good luck with your engine setup
b20powereDA
Jun 21, 2007 04:40 PM
