dizzy experts
im in need of a d16a6 dizzy but cant find one for a decent price. i have a few dizzys laying around some have problems some dont. what im wondering is first the easyest one will a d15b7 one work with obd0? all the wire colors are the same as a a6 one. i was thinking just swap over the older style plugs. second can i swap over all the internal parts of a obd0 ls dizzy into a d15b2 dizzy body? it looks like it will work. i know alot of the internal parts are interchangeable. the ls one has a bad bearing but i was thinking i could us the b2 bearings.
you can swap the whole internals into a obd0 dizzy housing. The only thing different on the dizzys from obd0-obd1 is the plugs..
What is your problem with your dizzy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX91SE »</TD></TR><TR><TD CLASS="quote">you can swap the whole internals into a obd0 dizzy housing. The only thing different on the dizzys from obd0-obd1 is the plugs..
What is your problem with your dizzy</TD></TR></TABLE>
so then if your right i can just swap plugs and be good then. the problem with my dizzy is i dont have one. i know where there is a d15b7 obd1 dizzy for cheap ill just get that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black0hatch »</TD></TR><TR><TD CLASS="quote">does no one know if a obd1 dizzy will work on a obd0 car?</TD></TR></TABLE>no - OBD1 distributor <U>will</U> <U>not</U> work with OBD0 ECU - the OBD1 distributor sensors are different and send different signals to the ECU which the OBD0 ECU can't recognize
What about the different gear in side the dizzy??? Didnt think about all that huh just posted crap.
It wont work.
It wont work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX91SE »</TD></TR><TR><TD CLASS="quote">whops scratch that, its the same dizzy it was obd1... But you can swap igniters for sure.. </TD></TR></TABLE>
oh man good thing i didnt pick up a b7 dizzy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc »</TD></TR><TR><TD CLASS="quote">lol
i think if you dont want to spend any money at all you should find a OBD0 MPFI dizzy with a good bearing and swap in a good coil/ignitor which you have lying around. seems the easiest way to me</TD></TR></TABLE>
ya but where am i going to find a broken a6 dizzy.
lilsicsoul
13
Jan 26, 2009 07:20 PM
