help verify
are these cams legit???they are going for way too cheap and i'm sure there is a catch to it. has any of you dealt with this ebay seller before?
http://cgi.ebay.com/ebaymotors...ZWDVW
ask for pics of the end of the cam, USDM itr cam has 1 ring at the end
they seem's very cheap. maybe this will help you out.
https://honda-tech.com/zerothread?id=1220152
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_import »</TD></TR><TR><TD CLASS="quote">are these cams legit???they are going for way too cheap and i'm sure there is a catch to it. has any of you dealt with this ebay seller before?
http://cgi.ebay.com/ebaymotors...ZWDVW</TD></TR></TABLE>
the seller doean't seem bad, has 22 negatives under 2300 sells. most likely, he started the bid low hoping it would go higher, but no one has made any bids.
remember, it's always a risk buying anything from ebay. like my uncle always says, you don't buy anything you can't touch.
I think they are knock off cams that they sell and not OEM cams. If they are OEM and came out of that head they showed then they are GSR. But again i think they are knock off/remade cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">I think they are knock off cams that they sell and not OEM cams. If they are OEM and came out of that head they showed then they are GSR. But again i think they are knock off/remade cams. </TD></TR></TABLE>
WOW, knock off cams? what's next?
