Integra brake swap? (searched)
Old Jan 4, 2008 | 06:46 AM
Ahh Vtec's Avatar
Default Integra brake swap? (searched)
i have everything needed for the swap, but my 92 dx hatchback axles are not working with the integra hubs? The spindle doesnt go all the way threw, but they work just fine on the stock hubs. What axles are you guys using with your brake swaps?
Old Jan 4, 2008 | 07:50 AM
philosofy1's Avatar
Default Re: Integra brake swap? (Ahh Vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahh Vtec &raquo;</TD></TR><TR><TD CLASS="quote">i have everything needed for the swap, but my 92 dx hatchback axles are not working with the integra hubs? The spindle doesnt go all the way threw, but they work just fine on the stock hubs. What axles are you guys using with your brake swaps?</TD></TR></TABLE>
you need to apply some elbow grease. the axle shaft is the same diameter (32mm) on the integra and civic. chances are the integra hubs probably has some rust on it, apply some lube and elbow grease and they will slide right in.
Old Jan 4, 2008 | 08:05 AM
Syndacate's Avatar
Default Re: Integra brake swap? (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
you need to apply some elbow grease. the axle shaft is the same diameter (32mm) on the integra and civic. chances are the integra hubs probably has some rust on it, apply some lube and elbow grease and they will slide right in.</TD></TR></TABLE>
Yeah, I was just gonna say rub some low grit sand paper on it to get any "build up" off of it, make it slide on easier. Make sure it's lubed liberally. Though unless it's out of round or the concentricity is off, it should go on.
Old Jan 4, 2008 | 08:20 AM
Ahh Vtec's Avatar
Default Re: Integra brake swap? (Syndacate)
Thanks for the replies, but we figured ity out. We had bought remanufactured axles from advance auto, because the oem ones were toast and we didnt feel like rebuilding them. Turns out the tolerences on the reman. axles were slightly off. they fit fine in the civic hub but not the integra.
So we went back to advance and they let us try the old cores which worked so then we tried the brand new axles that they had in stock and they worked. So the only thing i can come up with were the tolerences were out of spec just enough on the reman. axles to not fit the integra hubs.
We got everything figured out now, and thanks for the info.
Old Jan 4, 2008 | 08:23 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahh Vtec &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies, but we figured ity out. We had bought remanufactured axles from advance auto, because the oem ones were toast and we didnt feel like rebuilding them. Turns out the tolerences on the reman. axles were slightly off. they fit fine in the civic hub but not the integra.
We got everything figured out now, and thanks for the info.</TD></TR></TABLE>
i have bought axles from advanced tons of times before, but i have never had that problem. atleast they are no now, what ever works for you!
jdm12345
Jul 26, 2007 12:08 PM
jdm4drSi
Jan 3, 2005 07:54 PM
B2FiNiTY
Mar 11, 2004 10:18 AM
Propulsion
Aug 4, 2003 06:07 PM
civichopeful
Oct 13, 2002 03:42 AM
