Any difference in these two bottom ends?
Old Jun 29, 2002 | 11:31 AM
Damon B.'s Avatar
Default Any difference in these two bottom ends?
I have a 99 Civic Si, and I'm looking into getting a spare b16 short block to build up. Now is there any difference between the b16a2 bottom end and the first generation b16 bottom end? My plan is to send it to golden eagle to be bored out and sleeved. I'm thinking that the bottom end of both blocks should be identicle, am I wrong in thinking this?
Old Jun 29, 2002 | 12:12 PM
Damon B.'s Avatar
Default Re: Any difference in these two bottom ends? (CleanSi)
up
Old Jun 29, 2002 | 12:49 PM
B-series Assassin's Avatar
Only thing different I can think of is B16A2 has slightly higher compression pistons.
Old Jun 29, 2002 | 01:09 PM
Chugger's Avatar
Default Re: Any difference in these two bottom ends? (B-series Assassin)
yes sir just slightly higher
Old Jun 29, 2002 | 01:17 PM
Damon B.'s Avatar
Default Re: Any difference in these two bottom ends? (01VaS2K)
but that won't matter since i will be building the block with lower compression pistons. so the actual blocks are the same, every little bit of them, except pistons correct?
Old Jun 29, 2002 | 02:45 PM
Katman's Avatar
All US b16a's have the same compression ratio = 10.2 and run the same PR3 pistons. If you pick up a JDM 92+ B16A, then you'll have the 10.4 compression ratio piston aka P30 piston. The older JDM 89-91 b16's run the PR3 pistons, same ones found in all of the US b16's (delsol, 99+Si, etc).
Other than the pistons; the blocks are identical. ---BUT! ---
One thing you need to remember is that the pre-92 b16a (US or JDM) blocks will NOT have the OBD2 crank/CKP sensor that's built onto the oil pump! don't forget abou that! Unless you're running a jumper to an OBD1 ecu, then you wont' have anything to worry about.....but if you're not then take what I just mentioned into consideration...
[Modified by Katman, 3:46 PM 6/29/2002]
Old Jun 29, 2002 | 02:57 PM
Damon B.'s Avatar
Default Re: Any difference in these two bottom ends? (Katman)
So if I'm NOT running a jumper (meaning all my ecu stuff is stock obd2 ****) then I'll be fine? Or I need the jumper to make the first gen block w/ obd1 crank sensor mobober work? I'm little unclear on that part. Thanks
[Modified by CleanSi, 11:58 PM 6/29/2002]
Old Jun 29, 2002 | 05:37 PM
Damon B.'s Avatar
up, waiting for katman's response.
Old Jun 29, 2002 | 05:49 PM
GokuSSJ4's Avatar
you will need the jumper to obd1 to use it !
Old Jun 29, 2002 | 05:50 PM
GokuSSJ4's Avatar
Default Re: Any difference in these two bottom ends? (Spoon1)
same as some j-spec motors dont bring the sensor for the oil pump
Old Jun 29, 2002 | 11:27 PM
Katman's Avatar
No, you WON'T be fine if you keep your OBD2 schitt. You will get a check engine light and your car might run like garbage if you stick with the OBD2 ecu and run a pre92 b16a block. I mean all you have to do is buy a spare 96+ US B-series oilpump with CKP and slap it on a pre92 block and you should be fine. Otherwise if you went OBD1 ecu, you won't have to worry about that damn CKP sensor at all....or you can try to run a JDM OBD2 ecu and it won't look for that CKP sensor either, but JDM ITR ecu's kinda suck. The fuel mapping and ignition is wacky on most JDM ecu's.
Old Jun 30, 2002 | 12:52 AM
Damon B.'s Avatar
So I can just switch over that sensor from my current block along with all the other **** I'm going to swap from my current engine?
Old Jun 30, 2002 | 12:57 AM
jdmhatch94's Avatar
well the first gen block have oil coolers on them!!!! besided sensors and pistons they are the same pretty much
Old Jun 30, 2002 | 02:12 AM
Katman's Avatar
yes..well you need to swap the whole oil pump since the sensor is integrated into the pump itself.
Old Jun 30, 2002 | 10:07 AM
Damon B.'s Avatar
Well that doesn't sound like a big deal. Thanks.
Old Jun 30, 2002 | 10:47 AM
dj@wedreamz.net's Avatar
hey man i got a b16 short block i will seal you for like 200 out of a 2000 si it is compleat
Old Jun 30, 2002 | 11:29 AM
HXMan's Avatar
Default Re: Any difference in these two bottom ends? (dj@wedreamz.net)
What is wrong with it? I may be interested....
Old Jun 30, 2002 | 01:41 PM
Damon B.'s Avatar
YEah, give us info on it. I will buy it if it sounds good, but if I don't buy it and hxman does, good luck to him.
JPerkMr954
Feb 28, 2013 12:46 PM
00EckoSI
10
Dec 29, 2009 03:44 PM
CeeJayy
May 2, 2007 08:47 PM
Suck my DX
Apr 26, 2007 04:24 AM
Damon B.
Jun 29, 2002 05:38 PM
