Just installed a B16 in 88 Si, cant get clutch cable to work? Also throttle cable Q's...
Old Jan 3, 2008 | 10:06 PM
Dc4iNtEgRa's Avatar
Is Partying at your House
Default Just installed a B16 in 88 Si, cant get clutch cable to work? Also throttle cable Q's...
I just installed a B16 in my 88 CRX Si, and I cant get clutch cable to work? Im trying to use the stock one, but I have a 90 integra cable to use.
I heard you could use the stock one? Is there a specific way to do it?
I lost my throttle cable bracket off my manifold, what one will work for a obd-0 manifold?
Thanks Alex
Old Jan 3, 2008 | 10:33 PM
Dc4iNtEgRa's Avatar
Default Re: Just installed a B16 in 88 Si, cant get clutch cable to work? Also throttle cable Q's... (Dc4iNt
I've searched and found this but it doesn't say how to modify it...
# 44
https://honda-tech.com/zerothread?id=1193782
Old Jan 4, 2008 | 12:02 AM
crx.com's Avatar
If this is wrong some can correct me. The cable is slightly shorter. therefore when you install it on the cble mechanism it will be placing preasure on it engaging the clutch. What I did on my 91 si s to cut off about 1/2 inch of the cable bung(rubber piece at the end of th cable) that inserts into the mechanism. I took my time as I did not want to cut into the cable itself. Hopes this helps.
Old Jan 4, 2008 | 07:22 AM
Dc4iNtEgRa's Avatar
Is it possible to use a 90 integra cable?
Old Jan 4, 2008 | 08:40 AM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dc4iNtEgRa &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to use a 90 integra cable?</TD></TR></TABLE>
x2
u need both clutch and throttle cables for your swap.
Old Jan 4, 2008 | 08:46 AM
MarlonT42's Avatar
I used my stock Clutch cable and used a TypeR throttle cable that I got from the dealer new for like $20
Old Jan 4, 2008 | 04:18 PM
Dc4iNtEgRa's Avatar
Default Re: (MarlonT42)
will the integra clutch cable be too long to where I have to ajust it all the way to grab?
Old Jan 4, 2008 | 04:39 PM
iwantspeed's Avatar
Default Re: (Dc4iNtEgRa)
i paid like 35 bucks brand new from honda and hot the type r throttle bracket and throttle cable.. works perfect. cable is like 3 times shorter so it cleans your engine bay up a little..
Old Feb 29, 2008 | 12:22 AM
1kreationz401's Avatar
the stock civic si clutch cable does fit, you just got to put some strength into it, and the throttle cable i made my own aluminum plate. works great.....!
you can see in the picture below
Old Feb 29, 2008 | 07:51 AM
ActionJackson's Avatar
Default Re: (1kreationz401)
nice in...um filter
Old Feb 29, 2008 | 09:37 AM
alscrx's Avatar
Default Re: (ActionJackson)
For the throttle cable buy the $15 innovative bracket and use your stock cable.
I used my oem clutch cable. Its a biatch to get it in the trans fork but you can. I didn't trim any rubber and its fine
Old Feb 29, 2008 | 10:18 AM
m1k3typer's Avatar
i used the clutch cable bracket off of a DA and my stock DX clutch cable worked and not hard to install at all just gets a little tight around the battery but other than looks and works like stock
4gencivicef9
Apr 9, 2006 07:18 PM
civic889802
10
Dec 27, 2005 12:15 AM
Dosvita
Mar 20, 2005 03:01 PM
type Gendy
Jan 18, 2003 04:21 PM
BoostinDC2
Feb 17, 2002 05:41 PM
