EF8 FRONT END CONVERSION. HELP?
Old Jan 3, 2008 | 06:28 PM
EF9IMPORTER141603's Avatar
Default EF8 FRONT END CONVERSION. HELP?
I AM PURCHASING EF8 RIGHT HAND DRIVE FRONT END DIRT CHEAP. BUT IT DOES NOT COM WITH ANY OF THE BODY PANELS AND I WAS WONDRERING IF MY EF9 BODY PANELS FIT OR AM I GOING TO NEED TO GET TH SIR FRONT END PANELS? I NOW THAT THE HOOD WILL NOT FIT UNLESS I CHANGE THE RADIATOR SUPPORT CROSS T. SO IF ANY BODY HAS ANY IDEA IF IT WILL WORK FOR ME LET ME NO. THANKS.
Old Jan 3, 2008 | 06:35 PM
CRXBart's Avatar
Default Re: EF8 FRONT END CONVERSION. HELP? (EF9IMPORTER141603)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9IMPORTER141603 &raquo;</TD></TR><TR><TD CLASS="quote">I AM PURCHASING EF8 RIGHT HAND DRIVE FRONT END DIRT CHEAP. BUT IT DOES NOT COM WITH ANY OF THE BODY PANELS AND I WAS WONDRERING IF MY EF9 BODY PANELS FIT OR AM I GOING TO NEED TO GET TH SIR FRONT END PANELS? I NOW THAT THE HOOD WILL NOT FIT UNLESS I CHANGE THE RADIATOR SUPPORT CROSS T. SO IF ANY BODY HAS ANY IDEA IF IT WILL WORK FOR ME LET ME NO. THANKS.</TD></TR></TABLE>
Ok turn the caps lock off. IF you are just simply switching firewalls, you can do that, and retain all your stock exterior parts. What kind of car do you have? If you have a EF9, then you have no need to convert it to RHD for it already is.
Old Jan 3, 2008 | 06:37 PM
Johnny-Red's Avatar
So your gona make it right hand drive but put USDM parts back on it...I would think it would be the same to change usdm to jdm just opposite wouldn't it?
Old Jan 3, 2008 | 06:44 PM
alscrx's Avatar
Default Re: EF8 FRONT END CONVERSION. HELP? (Johnny-Red)
Makes no sense
Old Jan 3, 2008 | 07:27 PM
whiteknightef's Avatar
Default Re: EF8 FRONT END CONVERSION. HELP? (alscrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx &raquo;</TD></TR><TR><TD CLASS="quote">Makes no sense </TD></TR></TABLE>
ya i agree this is dumb unless you are converting the car to right hand drive.
Old Jan 3, 2008 | 07:30 PM
mike9571's Avatar
Default Re: EF8 FRONT END CONVERSION. HELP? (whiteknightef)
Ha okkk..
Im confused you bought an ef8 conversion for a ef9?
Old Jan 4, 2008 | 02:38 AM
Default Re: EF8 FRONT END CONVERSION. HELP? (mike9571)
SORRY GUYS ITS AN SI IT NOT YET AN EF9 BUT I HAVE EVERYTHING BUT THE FRONT CLIP TO TURN IT THE ENGINE SWAP IS IN PROCESS ASAP. I AM JUST WAITING TO GET THE FRONT CLIP TO DO SO. IF THAT HELPS AND I WAS ALSO WONDERING IF THERE IS ANY THAT KNOWS WERE I CAN FIND THE RED RESERVIOR COVERS. I WANT EITHER MUGEN OR SPOON BUT I CANT FIND IN THE RED. HELP. AND I NO I AM JUST GETTING ON SO EXCUSE ANY MISTAKES THAT I MAY PUT ON HERE.
Old Jan 4, 2008 | 04:26 AM
b16a1eg6's Avatar
Old Jan 4, 2008 | 05:30 AM
CRX Toad's Avatar
https://honda-tech.com/zerothread/2172731
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a1eg6 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Kseries_em
Honda Civic (2001 - 2005)
16
Feb 5, 2011 09:31 AM
rewerbcrx
Feb 16, 2006 01:35 PM
MJL
Oct 14, 2005 07:49 PM
pendejon
12
Aug 21, 2005 11:20 AM
SOHC_Brian
27
Apr 20, 2004 07:48 AM
