getting motor tuned/clutch break in
Well I'm going to be dropping in RM cams soon and also going to be replacing my clutch with a little more aggressive pressure plate/disk. Only problem is I'm going to be doing it all at once and how would i be able to tune my car without the clutch being broken in? obviously the car is going to be running like **** without a tune and bigger cams...
You should be fine aslong as you dont slip the clutch or pull off to harshly. Once the clutch is engaged you can beat on it. Its high RPM take offs and changes that will over heat your clutch, which you dont want to happen during break in.
