Is adjustable front camber kit really needed for lowered car?
Old Jan 3, 2008 | 11:54 AM
crazyguy's Avatar
Default Is adjustable front camber kit really needed for lowered car?
Is adjustable front camber kit really needed for lowered car? even there is no tire rubbing against the wall?
and the car is only lowered by 2".
thanks
Old Jan 3, 2008 | 12:02 PM
ke98248's Avatar
Default Re: Is adjustable front camber kit really needed for lowered car? (crazyguy)
For that kinda drop, no. And even if you were dropped 3 inches, I wouldn't recommend spending a few hundred on a front camber kit. If you really want to purchase one, get a skunk2 rear camber kit and a full alignment from a tire center/shop.
A full alignment should do just fine for your setup though.
Old Jan 3, 2008 | 12:18 PM
spatula's Avatar
Default Re: Is adjustable front camber kit really needed for lowered car? (ke98248)
you can make your own rear shim kit, and then get an alignment and have them set the tow to zero.
Old Jan 3, 2008 | 12:27 PM
jredhonn's Avatar
my car lowered on H&R w/ kyb agx, i have blox camber kit in the rear, nothing up front. did an alignment 6 months ago, dont see any tire wears so far
Old Jan 3, 2008 | 12:33 PM
PinoyDelSol's Avatar
* B A N N E D *
Default Re: (jredhonn)
All you really need is a alignment and that should do the trick for camber wear. And btw this is suppose to be posted in the suspension form. Good luck.
njl481
Suspension & Brakes
Feb 24, 2012 12:11 PM
FLACO EM1
Nov 27, 2008 01:39 PM
donger
Jan 30, 2006 01:10 PM
MaintenanceWhore
May 29, 2005 08:06 AM
KraZyCHOWMEIN
Dec 19, 2001 07:58 PM
