cluster lighting
Old Jan 3, 2008 | 09:51 AM
so-cal-em1's Avatar
Default cluster lighting
the gages work but no lighting
Old Jan 3, 2008 | 02:13 PM
BlueIntegraBoy's Avatar
Default Re: cluster lighting (so-cal-em1)
Do your dash lights work or not?
Old Jan 3, 2008 | 02:15 PM
B16B_coupe's Avatar
HRD PKR
Default Re: cluster lighting (BlueIntegraBoy)
did you check the fuse for it?
Old Jan 3, 2008 | 02:19 PM
Cln94EG1's Avatar
Default Re: cluster lighting (B16B_coupe)
Ok I'm going to restate this. So all my Gauges work but the Lights Don't come on whats the problem?
All you have to do is get a new dimmer switch or check all your fuse's
Old Jan 3, 2008 | 02:21 PM
93egSLEEPER's Avatar
Default Re: cluster lighting (cln92eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg &raquo;</TD></TR><TR><TD CLASS="quote">Ok I'm going to restate this. So all my Gauges work but the Lights Don't come on whats the problem?</TD></TR></TABLE>
haha thank you. yea check fuses and all your switches... or even take out the cluster to make sure the plug didnt come loose.
Old Jan 4, 2008 | 05:03 PM
so-cal-em1's Avatar
Default Re: cluster lighting (93egSLEEPER)
u know what i think it is the swith how much do they cost
Old Jan 11, 2008 | 08:11 PM
so-cal-em1's Avatar
BUMP it isnt that switch/...last night when i was driving
i hit a bump and all my gages lights went on//..then
i hit anouther bump and they turned off...whats up with that
Old Jan 11, 2008 | 08:16 PM
work2day's Avatar
* B A N N E D *
might want to check crank poisition sensor. this same thing happened to me and it was that sensor.
Old Jan 12, 2008 | 08:43 AM
nautique196's Avatar
Default Re: cluster lighting (work2day)
get a wiring diagram and check your grounds. If it came on and off like that you probably have a bad ground
Old Jan 13, 2008 | 06:21 PM
so-cal-em1's Avatar
where is that sensor located at
Old Jan 15, 2008 | 08:14 PM
Midori Bandit!'s Avatar
yeah where is that switch? my gfs car has the same problem. I have checked all the fuses and the Dimmer switch. like even the lights work but when the parking lights go on it blacks out, well just the odometer, rpm, fuel temp gauges. the highbeam, handbrake, turn signals etc do light up when used.........
Old Jan 16, 2008 | 08:10 PM
so-cal-em1's Avatar
Default Re: (Midori Bandit!)
honda tech problem not solved...not a first.lol
mynameisMUDD
12
Jan 16, 2010 02:10 PM
sins
Jan 13, 2010 03:22 PM
slow_cx
14
Dec 10, 2007 10:08 PM
frankfezzie
35
Oct 25, 2005 09:46 PM
ef civic
Oct 19, 2003 10:55 AM
