cluster lighting
Re: cluster lighting (B16B_coupe)
Ok I'm going to restate this. So all my Gauges work but the Lights Don't come on whats the problem?
All you have to do is get a new dimmer switch or check all your fuse's
Re: cluster lighting (cln92eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cln92eg »</TD></TR><TR><TD CLASS="quote">Ok I'm going to restate this. So all my Gauges work but the Lights Don't come on whats the problem?</TD></TR></TABLE>
haha thank you. yea check fuses and all your switches... or even take out the cluster to make sure the plug didnt come loose.
Re: cluster lighting (so-cal-em1)
BUMP it isnt that switch/...last night when i was driving
i hit a bump and all my gages lights went on//..then
i hit anouther bump and they turned off...whats up with that
yeah where is that switch? my gfs car has the same problem. I have checked all the fuses and the Dimmer switch. like even the lights work but when the parking lights go on it blacks out, well just the odometer, rpm, fuel temp gauges. the highbeam, handbrake, turn signals etc do light up when used.........
slow_cx
14
12-10-2007 10:08 PM
