Car drives, Bogging and then intermittent CEL!
Hi All,
I had created an earlier thread to find out whether my o2 sensor was on its way out:
https://honda-tech.com/zerothread?id=2183734
Had a CEL #41, but now it hasn't happened for a while. I was driving again today and it seemed fine and the car started to bog pretty bad only between 2-3K (after roughly 35-40mins driving), then all of a sudden I get a CEL and the bogging basically disappears.
When I switch the car off and then on again CEL disappears so I cant find out what CEL it's throwing, I can only go on what it threw before which was #41 (makes sense to be the same as i had only disconnected the o2).
Thanks for your help!
It's a JDM EG6: b16a, obd1, p30. I doubt it's the knock sensor - no CEL for it previously. I''ve just gotten the #41 and it all seems to be pointing to the o2 sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin »</TD></TR><TR><TD CLASS="quote">It's a JDM EG6: b16a, obd1, p30. I doubt it's the knock sensor - no CEL for it previously. I''ve just gotten the #41 and it all seems to be pointing to the o2 sensor.
41 is easy to deal with. just simply replace a new o2 sensor.that happened to me too
yeah most likely knock sensor and maybe plus traction control CEL if your ecu is jdm p30. i had been there. i have the exact same thing
and to be 100% sure. wait for CEL to come on and let the car idel while check the codes. p30 ecu makes b16a engien run like **** , and i know it is oem and right ecu for b16a engine, i bought a chipped p28 ecu and tuned by a pro and my jdm b16a sir2 has been running very very smotth since then
i dont have the TCS, but i've also never had a knock sensor CEL or issue. The only thing I did was run without the o2 connected, once plugged in then i've been getting the CEL on it. I've experienced the bogging like this previously but no CEL.
So do i just hook the paper clip up whilst the cars running and CEL on?
Thanks!
Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin »</TD></TR><TR><TD CLASS="quote">i dont have the TCS, but i've also never had a knock sensor CEL or issue. The only thing I did was run without the o2 connected, once plugged in then i've been getting the CEL on it. I've experienced the bogging like this previously but no CEL.
Thanks!</TD></TR></TABLE>
yesh...hook up the paper clip and let the car idel and check the CEL and let us knows what are the codes.
einzelherz
Jun 21, 2012 03:57 PM
