what motor is better b18c or b18c5?
Old Jan 3, 2008 | 07:09 AM
bigjay1six1's Avatar
Default what motor is better b18c or b18c5?
just the simple fact that which motor is better on a ek body
which make more hp
that will help me on what motor i can get for my hatch
Old Jan 3, 2008 | 07:11 AM
sicones's Avatar
Default Re: what motor is better b18c or b18c5? (bigjay1six1)
https://honda-tech.com/zerothread/878010
Old Jan 3, 2008 | 07:13 AM
Probot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/878010</TD></TR></TABLE>
/thread
Old Jan 3, 2008 | 07:18 AM
crazyguy's Avatar
if money wise is not an issue to u. go with b18c5 ITR swap. costs around $4500~$5000 B18C1 costs around $2200~$2700
Old Jan 3, 2008 | 07:20 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigjay1six1 &raquo;</TD></TR><TR><TD CLASS="quote">just the simple fact that which motor is better on a ek body
which make more hp
that will help me on what motor i can get for my hatch</TD></TR></TABLE>
B18C is JDM, it could be the Japanese equivalent of our Integra Type R (C5), or the GSR (C1) - yes, the code is the same for both.
Obviously a Type R B18C will have morepower than a GSR B18C, as a USDM B18C5 has more power than a B18C1.
Now when it comes to USDM vs JDM motors - the JDM motors usually sport about 10 more brake horsepower, due to slightly higher compression ratios.
So if you're talking about the JDM "Type R" B18C vs B18C5 - it's the B18C, though if you're referring to the GSR B18C vs B18C5, then it's the B18C5.
In Japan, B18C came in two flavors:
B18C = B18C5 (USDM)
B18C = B18C1 (USDM)
Because there's no numbers at the end of JDM engine codes, so I'm not entirely sure which engine you're talking about when you say "B18C"
Though between what's above and the link sicones posted, you should be able to figure it out.
My info was assumed based on the fact that you're looking at GSR and ITR motors that you were looking for the one with the most power..."better" is subjective, but for which has the most power - look above, look at the link, also.
Also:
http://en.wikipedia.org/wiki/Honda_B_engine
This should help you on your quest for which is "better" - lots of info there.
The Honda stuff is checked pretty regularly - because there's so many pple online in the "tuning" game - but do remember:
Old Jan 3, 2008 | 07:23 AM
crazyguy's Avatar
Default Re: what motor is better b18c or b18c5? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
very detail info
Old Jan 3, 2008 | 07:26 AM
Syndacate's Avatar
Default Re: what motor is better b18c or b18c5? (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">if money wise is not an issue to u. go with b18c5 ITR swap. costs around $4500~$5000 B18C1 costs around $2200~$2700</TD></TR></TABLE>
Gah, I completely forgot cost..
Yeah, @ OP:
These are accurate figures - so keep those costs in mind when you're comparing the 180bhp of the GSR to the 200bhp of the ITR. Personally I don't think the ITR is enough bang for ur buck over a GSR swap, as the figures clearly show, you're paying 185%-204% the price of the GSR for 20 brake horsepower by going for the ITR instead of the GSR - not worth it in my opinion, but the ITR is a great autoX motor due to its heavy all motor ability.
Old Jan 3, 2008 | 07:49 AM
gibsanez's Avatar
You can build a healthy GSR with the money you save instead of buying a Hype R
Old Jan 3, 2008 | 02:40 PM
the things is that i had a fully build gsr motor with type r internals so i was wondering if a real type will produce more power
Ekb18c5_BR
13
Sep 6, 2007 04:51 PM
baller78c4life
34
Mar 29, 2006 11:52 AM
da9wonder
Jun 18, 2005 01:16 PM
slowsi00
129
Nov 1, 2003 09:01 AM
vrrodri
Jul 16, 2003 07:30 AM
