Painting a car in a cold garage....
What are the cons of shooting primer/base/clear in cold/freezing temperatures inside a normal 2-car garage?
What about running a big space heater or two at the same time...do you leave it on while painting? I understand you don't want any dust being kicked up by the "torpedo" type space heater (which is the type I have)
I just don't want my house or something to blow up while painting a car in a propane heated garage :D
buy some 220v 4000watt workspace heaters... get some thermometers... you should be ok
im shooting in my garage (with 2 1500watt space heaters and a propane heater i usually leave off)
it gets to about 14deg celcius and about 55% RH which is good enough to shoot in for sure
so you don't want to excessively heat your garage up (as in to "bake" the paint on?)
i don't have a thermostat, but my heater on the lowest setting gets my garage warm enough that i can work in a long sleeved shirt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">cold car = more runs. not fun </TD></TR></TABLE>
No true.
All you need to do is change your technique of spraying and use a fast reducer. Ive sprayed several cars in a cold garage without running it.
No true.
turboteener
Welding / Fabrication
Jul 24, 2007 04:37 PM
eurodeseo
Jul 4, 2006 06:55 PM
