building b series swap mounts for 86-89 accord (possable to buy the pri patent?)
Old Jan 2, 2008 | 04:17 PM
SQ is the SQUAD's Avatar
Default building b series swap mounts for 86-89 accord (possable to buy the pri patent?)
i got a couple of people intrested in some b series swap mounts for 86-89 accord. i need a set for myself. the only sets know to man where the sets made by placeracing inc. we all know they been out of business for a few years now. anyone know these guys? i may be intrested in buying the schmeitics for there mounts.
on the other side, i got a kid bringgnig me a 1st gen b16a so i can make it up to my jig car, it really can be all to hard building the mounts myself, just got to do alot of measuring.
any suggestions?
Old Jan 2, 2008 | 07:08 PM
HiProfile's Avatar
Default Re: building b series swap mounts for 86-89 accord (SQ is the SQUAD)
For mounts, you can do what I mentioned in the other active thread about mounts.
Other than making it clear the hood (add the extra amount needed for b18 deckheight and motor movement) and making the axles close to level, and you should be fine.
Old Jan 2, 2008 | 08:42 PM
rorik's Avatar
Default Re: building b series swap mounts for 86-89 accord (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">For mounts, you can do what I mentioned in the other active thread about mounts.
Other than making it clear the hood (add the extra amount needed for b18 deckheight and motor movement) and making the axles close to level, and you should be fine.</TD></TR></TABLE>
The other threads seems like it's not about much more than what material to use to make the inserts..
..but either way, there is so much info on 3geez about how to do this, just do it.
I just put a vtec head on my b series swapped 3g, (not even close to running though) can't believe my hood actually closes..
sseo89
Jul 14, 2017 12:06 PM
92egboost
Jul 18, 2008 07:02 AM
slowpokecivic
May 31, 2008 08:16 PM
black0hatch
May 31, 2008 05:01 AM
jaminonyourface
Oct 20, 2003 07:43 AM
