Kakimoto Racing catjack for DC2
Old Jun 29, 2002 | 05:19 AM
mafay2's Avatar
New User
Default Kakimoto Racing catjack for DC2
Here is a picture of the Kakimoto Racing catjack (test pipe) for the DC2.
Connection of the catjack to the catback.
Old Jun 29, 2002 | 06:37 AM
6ghatch's Avatar
Default Re: Kakimoto Racing catjack for DC2 (mafay2)
Is that "JDM" sized so you dont need to shorten anything? Do they make one for the EK hatch? I have a Fujitusbo exhaust, and my test pipe is all hacked up, cut and welded 3 times for the correct fit.
Old Jun 29, 2002 | 09:58 AM
BPT DC5's Avatar
Default Re: Kakimoto Racing catjack for DC2 (6ghatch)
If your header has a 2.5" collector, then this will fit your EK Fujitusbo piping. A Spoon Header, Kakimoto Cat Jack and Fujitsubo Power Getter EK Hatch Combination was tested before and bolted up with no problems!
Old Jun 29, 2002 | 10:07 AM
Big Phat R's Avatar
That looks a lot like the Spoon catjack - ?
Old Jun 29, 2002 | 10:37 AM
Type-Rare#1248's Avatar
Default Re: Kakimoto Racing catjack for DC2 (9Grandr)
i was getting very interested until i found out that it was a test pipe
Old Jun 29, 2002 | 10:46 AM
Sima's Avatar
Default Re: Kakimoto Racing catjack for DC2 (Type-Rare#1248)
Anybody know what kind of gains you can get with a Test Pipe vs. a stock cat...
Old Jun 29, 2002 | 10:50 AM
Toda-R's Avatar
Banned
You can check it out on Kakimoto's website: http://www.kakimotoracing.com The price is in the Spec section. Or you can call them at (604)325-1882 and they will probably work a deal out for you!
Old Jun 29, 2002 | 11:29 AM
hooptie157's Avatar
Default Re: Kakimoto Racing catjack for DC2 (Sima)
http://www.importreview.com
Old Jun 29, 2002 | 11:43 AM
BPT DC5's Avatar
Default Re: Kakimoto Racing catjack for DC2 (Phat Bastard)
Yes, it might look like a Spoon Cat Jack, but it it made by Kakimoto Racing themselves. The Spoon Cat Jack is no longer available if I am correct.
And yes, it is only a test pipe. Not a functional Cat.
Old Jun 29, 2002 | 01:05 PM
mafay2's Avatar
New User
The gain you will get from a catjack(testpipe) is really depend on the mods you have in your car. For a stock ITR or ITR with I/H/E only, it probably won't give you too much gain. But if you are running some high lift camshaft and high compression, you will probably see up to 5-7whps gain on it.
Also, this catjack is perfect replacement for the stock cat for ppl running 2.5" header with JDM exhaust. Make everything a perfect bolt on!!
xxwolfsrainxx
Dec 9, 2012 04:06 PM
07 4DR Si
Honda Civic (2006 - 2015)
Jun 27, 2007 08:08 PM
