Car wont start need guru help
Old Jan 2, 2008 | 01:57 PM
Rukusmasta2's Avatar
Default Car wont start need guru help
Ok soo...its a 91 OBD0 Integra.Had b16ain there running fine. Swapped my OBD1 GSR motor in there the other day.It started but wouldnt hold idle, I had to stay on the gas for it to run. CEL came on, IACV.I then swapped the OBD0 TB and IACV onto my manifold and now the motor doesnt even start????? Also why are there like 3 extra coolant hoses on my GSR motor??? i have them plugged off so whatever.
Old Jan 2, 2008 | 02:26 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: Car wont start need guru help (Rukusmasta2)
Are you using a obd0 or obd1 ecu? obd0 or obd1 injectors?
Old Jan 4, 2008 | 04:40 AM
Default Re: Car wont start need guru help (St Jimmy)
sorry dude i thought i had wrote that up there but i guess not. im still runnin OBD0 and i have the OBD0 injectors in there too, everythign is OBD0 except my motor itself but dizzy, injectors, TB, IACV , ECU, all that is OBD0.
Old Jan 4, 2008 | 08:43 AM
mike-y's Avatar
did you find out why the IACV wasn't working the first time? Did you check continuity in the wire from the IACV connector to the ECU before you swapped them?
Also, did you try the idle adjustment screw on the throttle body?
Old Jan 5, 2008 | 08:33 AM
Default Re: Car wont start need guru help (mike-y)
i have no idea why it didnt run right the first time, i figured maybe i should put the old IACV in there because i removed the b16 and that thing was running like a clock in there, so i figured put the IACV that was in there and now it doesnt start at all.
Old Jan 6, 2008 | 09:05 AM
BUMP
Old Jan 10, 2008 | 03:27 PM
someone??
Old Jan 11, 2008 | 09:46 AM
man this aint like back in the day where everyone would chime in and say something.
Old Jan 12, 2008 | 08:33 AM
ttt
Old Jan 13, 2008 | 12:01 PM
Old Jan 18, 2008 | 05:33 AM
someone.........
Old Jan 18, 2008 | 06:18 AM
LsVtecFoti's Avatar
you might have to flash your ECU bro.. if not.. also check your timing belt.. if you said it only holds idle.. and you have to step on the gas to idle.. that could be the timing, you could always just get a p72?? I think correct me if im wrong.. I believe thats the 5speed GSR computer.. it might not be recognizing the cams... * shrugs* theres many different things bro.
Old Jan 18, 2008 | 06:22 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Car wont start need guru help (LsVtecFoti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtecFoti &raquo;</TD></TR><TR><TD CLASS="quote">you might have to flash your ECU bro.. if not.. also check your timing belt.. if you said it only holds idle.. and you have to step on the gas to idle.. that could be the timing, you could always just get a p72?? I think correct me if im wrong.. I believe thats the 5speed GSR computer.. it might not be recognizing the cams... * shrugs* theres many different things bro. </TD></TR></TABLE>
"bro", again you are an idiot...he stated that the issue lies between the TB and IACV, as evidenced by the results occurring upon swapping them between obd0 and obd1....neither of those has ANYTHING to do with the timing belt, "bro"
please don't open your mouth and post random incorrect things
to the OP, get the vaccuum diagrams for both obd0 and obd1....check all sensors directly related to the IM as well (map, tps, iacv, etc)
Old Jan 19, 2008 | 09:59 AM
Default Re: Car wont start need guru help (GRAF-FITI)
good **** graf-fiti....BUMP
Old Jan 19, 2008 | 10:06 AM
LsVtakn's Avatar
* B A N N E D *
Yeah, the gsr IM is a bitch. I ls/v'd my **** and ever since I havent gotten the idle under 1500. The vacuum lines and sensor are probably what it is. good luck
Old Jan 19, 2008 | 10:51 AM
Default Re: (LsVtakn)
im pretty sure i have them all right though
Old Jan 20, 2008 | 12:21 PM
Default Re: (Rukusmasta2)
im so mad at this it aitn even funny.
Old Jan 20, 2008 | 01:17 PM
b20integrapower's Avatar
IIRC there are two plugs near the back of the intake manifold that can be interchanged. Make sure you dont have them swapped.
Did you clean the IACV when you took it out? Spray it with carb cleaner and dry it out.
Old Jan 20, 2008 | 04:52 PM
Default Re: (b20integrapower)
yea IACV is clean. and let me remind you that this is not a stock GSR IM with the dual butterfly **** or whatever its a skunk2 IM.
Old Jan 26, 2008 | 06:36 AM
bump
Old Jan 27, 2008 | 08:10 AM
ttt
Old Feb 2, 2008 | 07:14 AM
still need this running.
Old Feb 7, 2008 | 04:35 PM
up
Old Feb 8, 2008 | 12:53 PM
ok so now for some reason i changed nothing after weeks of trying to start it just starts today for some reason?!?!?!?!? i absolutley changed nothing at all, WTF!!! but theres problems
knoklu
Apr 6, 2010 12:26 PM
knoklu
Apr 5, 2010 08:52 PM
Homotor
Feb 16, 2008 08:40 AM
Sinner
Oct 25, 2004 06:30 AM
filthyCREX
35
Feb 20, 2004 05:36 AM
