Suspension & Brakes Theory, alignment, spring rates....
92-95 lowering springs
Old Jan 2, 2008 | 09:50 AM
boostedNOTHARDLY's Avatar
Default 92-95 lowering springs
I've never messed around with a honda's suspension before, but i am wanting to put lowering springs on. Is there any "Putting springs on for Dummies" guides around here? or can anyone explain the steps? preferably the easiest and quickest
Old Jan 2, 2008 | 01:46 PM
_BEN_'s Avatar
Default Re: 92-95 lowering springs (boostedNOTHARDLY)
Once you have the suspension apart it is pretty straight forward.
The best thing to reference is a Helm or Haynes manual.
I would say the easiest thing to mix up is the order the washers and boot stack back up on the shock shaft. So pay special attention to that. Especially the washer with the tapered hole.
Another thing you will need to pay special attention too is the alignment of the studs on the top hats and to make sure the springs are as low as you can get them on their lower perches.
After you install them make sure you get your car aligned.
Old Jan 2, 2008 | 01:49 PM
alright. i'll check an online manual for those. maybe that'll help. and definatly getting it alligned after putting them on
Old Jan 2, 2008 | 02:01 PM
_BEN_'s Avatar
Default Re: (boostedNOTHARDLY)
You can pick up the haynes manual at your local auto store.
The helms manuals are expensive if bought ligitmately but dfinately worth it.
Old Jan 3, 2008 | 08:11 PM
EK_B's Avatar
https://honda-tech.com/zerothread?id=1278794
https://honda-tech.com/zerothread?id=1078663
GoLowDrew
Suspension & Brakes
Mar 27, 2011 04:58 PM
31flavorscivic
Suspension & Brakes
11
May 5, 2010 07:32 AM
treplatano
11
Jul 14, 2005 05:47 PM
Tofurky
Oct 7, 2002 04:42 PM
badnan
Jun 5, 2002 01:29 PM
