Rear brake lines (disk)
Old Jan 2, 2008 | 09:45 AM
nihad's Avatar
Default Rear brake lines (disk)
Ok i am looking for some rear brake lines and i heard that the russel ones are different
like the crx ones and the newer civic delsol that they are shorter. I need some for a 91 crx si i didn't know they were different length. And are the stock ones all the same.
Old Jan 2, 2008 | 10:00 AM
Ermil's Avatar
Default Re: Rear brake lines (nihad)
E-brake lines? Brake hoses? What now?
Old Jan 2, 2008 | 10:30 AM
nihad's Avatar
Default Re: Rear brake lines (Ermil)
the oil hoses
Old Jan 2, 2008 | 10:48 AM
Ermil's Avatar
Just order them for your application.
Old Jan 2, 2008 | 10:51 AM
alscrx's Avatar
Your title says brake lines, but assuming for calipers.
You can get on here from the seller Tech1hid
they are techna-fit lines and are dot approved and a direct fit for the crx. I have them and can vouche for them
Old Jan 2, 2008 | 11:00 AM
CRX Toad's Avatar
You post is very confusing if you need rear disc brake lines just order them for 91 CRX Si I have 92 Integra rear lines on my car.
Old Jan 2, 2008 | 11:08 AM
nihad's Avatar
i was asking about the rear ones i have heard that the delsol and the civic ones are diffrent from the 91 crx ones and the integras that the delsol ones are shorter. Is this right i wouldnt understand why they are shorter it should be the same. can some one shine some light on this
Old Jan 2, 2008 | 11:42 AM
PuroMotor's Avatar
Your better off ordering them for your application. I have Goodridge stainless steal lines on the rear.. no complaints.
Old Jan 2, 2008 | 11:47 AM
alscrx's Avatar
Default Re: (PuroMotor)
Yes some are shorter some are longer depending on the chasis. Our cars are small compared to integra's.......
who cares anyway, just order them for the rex
Old Jan 23, 2008 | 05:40 PM
trip-doh's Avatar
What about for the EF sedans? Which application would you use? CRX?
Old Jan 23, 2008 | 05:48 PM
bprsk8r4272's Avatar
Default Re: (trip-doh)
for the e-brake lines = integra
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trip-doh &raquo;</TD></TR><TR><TD CLASS="quote">What about for the EF sedans? Which application would you use? CRX?</TD></TR></TABLE>
Old Jan 23, 2008 | 05:57 PM
tnez's Avatar
x5... that will be your best bet. maybe da integra rear lines or civic hatch of the same year?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ermil &raquo;</TD></TR><TR><TD CLASS="quote">Just order them for your application.</TD></TR></TABLE>
Old Jan 23, 2008 | 06:38 PM
trip-doh's Avatar
I'll use the CRX Si brake lines. I believe that would work. E-brake 4-door DA?
type Gendy
Nov 15, 2007 04:23 PM
Reelizmpro
Jul 12, 2007 05:05 PM
WVTURBOCRX
Nov 27, 2005 06:29 PM
SoulSurfer
16
Apr 30, 2004 03:50 PM
