best cams for my Built B16
Old Jan 1, 2008 | 05:25 PM
TurboB16A300Hpteg's Avatar
Default best cams for my Built B16
Im running a 8.5.1 comp b16a with a t3/t67 dual BB turbo with full race ram horn 3 inch dp U think gsr cams would be good for this setup and help out with Spool time n also make my vtec more agresive when it hits crossover
Old Jan 1, 2008 | 05:43 PM
T4eg's Avatar
Default Re: best cams for my Built B16 (TurboB16A300Hpteg)
search... itr cams would work fine.... u have a b16 in a integra??
Old Jan 1, 2008 | 06:08 PM
Schister66's Avatar
Man U FTW
If you search Archived Content or even a basic search, you'll find a lot of results.
Old Jan 2, 2008 | 03:02 AM
007EG's Avatar
Default Re: (Schister66)
GSR or ITR in my opinion. Depends on how crazy the setup is too and how much boost you plan to run. Also, are you on a budget or do you have tons of money to spend?
Old Jan 2, 2008 | 04:26 AM
turbotypeR@SPEC's Avatar
25 Year Member
gsr and itr both work great. the gsr will havea lower power band and the itr will have a higher power band with more top end power. if you are using this car more on the street, i would use the gsr. also, you can usually find the gsr's pretty cheap
Old Jan 2, 2008 | 05:05 AM
Default Re: best cams for my Built B16 (turbotypeR@SPEC)
yes on a budget... gunna be 14-18 psi on my t3/t67 dual BB im gunna have a set of M factory Cam gears mated with them... u think this will help my spool time at all with the gsrs???
Old Jan 2, 2008 | 05:30 AM
MidShipCivic's Avatar
Default Re: best cams for my Built B16 (T4eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg &raquo;</TD></TR><TR><TD CLASS="quote">search... itr cams would work fine.... u have a b16 in a integra??</TD></TR></TABLE>
Nothing wrong with a B16a I'm going with one in my DA as well.
Old Jan 2, 2008 | 06:44 AM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16A300Hpteg &raquo;</TD></TR><TR><TD CLASS="quote">yes on a budget... gunna be 14-18 psi on my t3/t67 dual BB im gunna have a set of M factory Cam gears mated with them... u think this will help my spool time at all with the gsrs???</TD></TR></TABLE>
you can usually sqeeze a little more mid range with the cam gears. i would also upgrade valve springs in the b16 if you do any bigger than the gsr's.
jeryjohn
May 19, 2010 08:19 PM
ed rex
Jan 10, 2009 08:44 AM
type Gendy
Dec 11, 2007 10:51 AM
kshgl87
Jul 24, 2007 12:57 PM
alfee
Nov 1, 2003 10:59 AM
